Jon Ison
| posted on 18/3/10 at 08:27 AM |
Busa speed output/digidash ?
Anyone used the output from the busa loom to signal the digidash speedo ?
Doable ? <-nice word.
TimC
| posted on 18/3/10 at 08:28 AM |
Try BobM on the RGB forum Jon.
Its good to see that you are still alive this morning.
turbodisplay
| posted on 18/3/10 at 09:30 AM |
as long as the speed output is digital, it should be ok.
If the speed sensor has three wires it will be ok.
Darren
sucksqueezebangblow
| posted on 18/3/10 at 09:46 AM |
Not sure if you are using chain drive or a prop shaft. If you are using a prop shaft you will have a challenge with the position of the speed sensor.
It is under the output sprocket cover and reads a target on the end of the output shaft. You will need to remove it to fit an output flange and
prop.
You might be able to fit it elswhere, for example by fitting targets (4 I believe) on the prop shaft. Steel should do as I think the sensor is Hall
Effect but check the material of original target on the end of the output shaft to be sure.
richard thomas
| posted on 19/3/10 at 09:24 PM |
Seem to remember that it's 2 wires....?
Jon Ison
| posted on 20/3/10 at 09:34 AM |
Hi, can someone confirm where the speed output is situated ?
I haven't looked, just assumed it would be like the Bird I had a few wires out her gearbox ? Sounds rude ?
richard thomas
| posted on 20/3/10 at 01:24 PM |
Speed sensor is located at the gearbox output for the sprocket. There is a toothed wheel on the output shaft which the sensor picks up from.
