kylerichmond
posted on 5/4/10 at 06:45 PM |
zetec zx9 carbs
I have just started my Zetec 2.0L, however there appears to be blow back through the carbs what would cause this?
Timing issue?
jacko
posted on 5/4/10 at 06:50 PM |
If you mean spitting they all seam to do this
Mine do
posted on 5/4/10 at 06:51 PM |
Have you blocked the upper air hoses?
Give me a shout and I'll come down and see if I can help.
55ant
posted on 5/4/10 at 06:52 PM |
mine occasionaly seem to puff a fine mist of fuel. zx9 carbs aswell on a pinto
deltron63
posted on 5/4/10 at 07:07 PM |
mist from mine as well
lotusmadandy
posted on 5/4/10 at 07:17 PM |
And mine.
kylerichmond
posted on 5/4/10 at 07:48 PM |
When i mean blow back, i understand that the mist is normal, it was like a misfire through the carb, i could see like a flame on each carb, it happens
just sometimes not constantly, is this normal?, cheers steve i might take you up on that offer, really im just needing advice on getting the carbs set
up, jet sizes etc,
i have not blocked the top air pipes and not blocked the air bleeds yet, 190 mains, any advice is appreciated
Danozeman
posted on 5/4/10 at 07:57 PM |
cam timing will give you blow back through the carbs that would do it all the time though.
Does it rev ok? Are the diaphragms sealed ok?
Dan
kylerichmond
posted on 5/4/10 at 08:13 PM |
Yeh it revs up ok. just a bit lumpy low down however if i put the choke on everything smooths out, i aint blocked anything off at all
ashg
posted on 5/4/10 at 09:34 PM |
my zx6 carbs used to chuff until they were setup properly. they never do it now.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
posted on 6/4/10 at 09:20 AM |
May need balancing, I can bring my gauges as long as you have vacuum take offs?
