Author: Subject: Formula 27 - road/track car
ch1ef
posted on 10/4/10 at 11:19 AM Reply With Quote
Formula 27 - complete factory kit built.
711M 1600cc Xflow engine, rebuilt 5500miles ago with;
New pistons
New Rings
New Bearings
New oil pump
New Kent cam
New followers, valves, valve springs.
New rocker assembaly
Balanced and lightened.
New crank assembaly
New flywheel
New clutch
Burton rocker cover
4 branch tubular manifold
stainless steel exhuast
NEW thermostat
new fan temp switch (88degrees)
NEW alternator
Reconditioned starter motor.
NEW spark plugs
HT leads and dizzy
4 speed gearbox
Gaz adjustable coilovers
New Track rod ends
New steering rack boots
Weller light weight racing wheels
New fuel lines
Yokohama cut slicks on front and firestone tyres at rear both with lots of tread
Willan harnesses
Fibre glass seats
Wet weather gear supplied (no corrently fitted, just needs to be bolted on and poppers added)
The car myself and a friend have owned for 6 years, unfortunatly we have neither had time to use it for the last few years and its seems a waste to not be used much for another summer so reluctantly we have decided to sell the car (too many projects and not enough spare time!)
I spent alot of time over the last few months adding new bits to the car. It is in very good working order and makes very good power. The carbs have been tuned to suit the extra modifications added to the engine.
Points to note;
front toe needs laser aligning (since I added new track rod ends)
Volt guage is not working (temp gauge was reading out but I think I have sorted this now)
£3000 as it stands
£3200 with MOT and tracking laser aligned
£3310 with MOT and tracking laser aligned and road tax
I have given the above options as I know alot of cars are just used on track. Also I have no local garaged to me I trust so will need to take the car across town to my trusted garage (this is why a discount is given to taking the car "as is"
Car is located in Bristol
Viewing welcome anytime and delivery could be arranged at buyers cost
pewe
posted on 10/4/10 at 05:11 PM Reply With Quote
NTDWM but sounds like a bit of a bargain.
Factory built F27's normally change hands for more.
Is it live or independent rear end?
Whichever due to their rocker arm front end which allows more suspension travel than normal Se7ens they hold the road superbly.
BOL selling it.
Cheers, Pewe
ch1ef
posted on 12/4/10 at 04:31 PM Reply With Quote
Its got live rear suspension. The car is running very tiff setup at the rear and a reasonable stiffness at the front and its makes fo one of the best handleing sevens I have driven. But wont quite match my ZX9r mk indy
eddie99
posted on 12/4/10 at 04:42 PM Reply With Quote
I can't believe that! Bargain!!!!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
ch1ef
posted on 13/4/10 at 06:39 AM Reply With Quote
I have tried to make it a good deal, ready to drive all summer
ch1ef
posted on 15/4/10 at 06:48 AM Reply With Quote
viewings welcome this weekend
