Stott
| posted on 9/5/10 at 02:02 PM |
Acewell RPM + or - of coil (std dizzy)??
My acewell instructions show the tacho input coming from the + side of the coil, is this right? will it sense?
Strange not to be on the switched side I thought.....
Any help would be great, cheers
Stott
couch22k
| posted on 9/5/10 at 04:25 PM |
Hi Stott
I put mine to the - side this week worked spot on. This was with a Lumination electronic ignition (Pinto).
Stott
| posted on 9/5/10 at 08:09 PM |
Thanks, thought so, it's been the case with every tacho I've seen, I'm running a 2.0 pinto with ford ESCII so I'll do it like
that
Stott
tony-devon
| posted on 10/5/10 at 03:22 PM |
correct it goes to the negative side
the positive is a constant 12v to the coil, its the negative side that is being switched
heavy is good, heavy is reliable, and if it breaks, hit them with it
