Northy
posted on 17/5/04 at 08:16 PM |
Getting there......
Slowly
Graham
posted on 17/5/04 at 08:39 PM |
Looks well Northy!
Those seats are high... where are your harnesses/belts going to thread?
[Edited on 17-5-04 by Hellfire]
Northy
posted on 17/5/04 at 08:46 PM |
Using 3 point fixed bekts for the SVA as the rear top rail is too high. You can just see the tubes in the roll bar for the top fixing.
If I fit harnesses after SVA I'm hoping they'll just come round the sides....
Graham
alister667
posted on 17/5/04 at 10:24 PM |
Yep, looking well.
http://members.lycos.co.uk/alister667/
andrew-theasby
posted on 17/5/04 at 10:44 PM |
Looking good, like the wheels. Did you make your own manifold in the end? Where did you get the tube from or did you get the bends pre made? Ive
heard theres a place at elvington on an industrial estate that sells it.
posted on 18/5/04 at 09:34 AM |
Exhaust tail pipe.
Is it an optical illusion or does your tail pipe point upwards. This may cause concern if it's on the kerb side. It's less noisy if it
points down as well.
posted on 18/5/04 at 09:46 AM |
Pete,
less noisy if it points down? How does this work then? Surely it makes the same noise regardless of where its pointed.
Northy
posted on 18/5/04 at 05:34 PM |
Yes Pete, it does point up.
How can it affect the noise?
I'll be using one of these to test it, as it's what I design as a day job
Graham
gjn200
posted on 18/5/04 at 05:48 PM |
Sound is very directional.Imagine the end of the pipe is like a trumpet, louder in front of it than from behind. You dont want it pointing towards the
tester!
P.s Can you measure the width of your car for me please
[Edited on 18/5/04 by gjn200]
<- Me!
Northy
posted on 18/5/04 at 06:11 PM |
At which end?
Graham
gjn200
posted on 18/5/04 at 09:11 PM |
The widest bit, I want to know if it will fit through a fence panel gap.
<- Me!
Northy
posted on 18/5/04 at 09:16 PM |
172 cm at the back
Graham
gjn200
posted on 18/5/04 at 09:18 PM |
Top man!
<- Me!
Northy
posted on 18/5/04 at 09:23 PM |
Will it fit then?
Graham
gjn200
posted on 18/5/04 at 09:31 PM |
Just! 100mm gap
<- Me!
posted on 19/5/04 at 10:04 AM |
It just does. If you stand in front of a noise source it is louder than standing to one side of it. The tester puts his meter at 45* back from the car
about a metre away and asks you to rev to 2/3 of your maximum. He might not like you blowing fumes at and possibly burning pedestrians with a
backfire. All points to consider.
posted on 19/5/04 at 10:13 AM |
When SVA'd, we initially failed on the noise test. (104 db) The tail pipe was pointing towards ground and noise must have been bouncing down and
up into noise meter. When orientation of tail-pipe was changed to horizontal, the reading reduced to 102 db.
posted on 19/5/04 at 01:41 PM |
We (ah-hem) had inspiration to stuff some wire wool into the exhaust to bring it down within acceptable levels
From your post in the sva section Hellfire. Do you think this might have been something to do with it as well.
posted on 19/5/04 at 02:08 PM |
Yeah, possibly. Although the wire wool thing was our third attempt to get the noise level less than 101 db.
What I'm getting at, is, pointing the tailpipe down to the ground may not reduce the noise level picked up by the meter.
Northy
posted on 19/5/04 at 07:56 PM |
Sound does indeed bounce off surfacre and reflect but I'll not bore you further.
I'm not worried about the test as I have unlimited access to Sound Level Meters o measure my car, so will have a good idea if it'll pass.
Also they use our Meters I think
I also know all the right (read dodgy) questions to ask if it fails, and will also know if he's doing something wrong
