New Topic New Reply
Author: Subject: throttle cable
garysenter
posted on 27/5/10 at 07:47 PM Reply With Quote
throttle cable
need a new throttle cable for mk indy running 2 litre zetec...the current one has been chopped down and has no nipples on either end....anyone know where i could get one? or would i still have to chop down to give correct length?
gary
Bumble
posted on 27/5/10 at 07:59 PM Reply With Quote
I recently bought a universal kit from thesse guys.
http://www.venhill.co.uk/Home
Top quality and good value.
HTH,
Matt
dlatch
posted on 27/5/10 at 08:37 PM Reply With Quote
see above post the venhill ones come with all the ends you would ever need
austin man
posted on 27/5/10 at 08:55 PM Reply With Quote
Ive used bike brake cables for 3 years no problems
garysenter
posted on 28/5/10 at 06:30 PM Reply With Quote
thanks guys......will have a look at what exactly is fitted on my car....then first port of call will be to attack one of the unused mountain bikes in the shed lol
garysenter
posted on 28/5/10 at 08:18 PM Reply With Quote
think i solved my problem....the throttle was very jerky in its motion despite trying to lubricate....on closer inspection i noticed the route the cable took gave it 2 fairly tight turns so i re routed it along a much "friendlier" path and the whole thing is much more fluid in its motion......hopefully i can get the much needed smoother take offs instead of breaking my neck each time
New Topic New Reply
