Author: Subject: Did I buy the wrong microbore pipe?
Mark Allanson
posted on 29/5/04 at 09:49 PM Reply With Quote
I bought a reel of 8mmx0.6mm microbore for my fuel lines, but the bloody stuff is totally unbendable, I bought a screwfis small bender for the job, but all it does is neatly crush the pipe, rather than the complete hash of bending it over a socket
ady8077
posted on 29/5/04 at 10:20 PM Reply With Quote
Hi Mark
I've used 8mm microbore, didn't use a bender though just my hands. Didn't try to bend it to tight and i could feel it stiffening up as it bent
Adrian
RoadkillUK
posted on 29/5/04 at 10:28 PM Reply With Quote
You can buy a bending tool, it's a spring that fits around the pipe (as opposed to the internal one for larger pipes). I used one myself and it did a very nice job.
Can't find a bleedin' link to one, sorry.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Mark Allanson
The stuff I have will not bend at all without flattening, did you have 0.6mm wall thickness?
Avoneer
posted on 29/5/04 at 10:55 PM Reply With Quote
Don't know exactly what Tiger supplied, but it helped leaving it in the warm airing cupboard until required!
Pat...
mangogrooveworkshop
posted on 30/5/04 at 07:36 AM Reply With Quote
Macspeedy tol me the other day that those small pipebenders need modifyied to fit the pipe in instead of on top the former. If they have paint or powdercoat in the groove this causes the hassel.
Said he cleaned it out with a small round file to make the pipe sit in the former.
hope that helps.
posted on 30/5/04 at 08:13 AM Reply With Quote
Try annealing the pipe where you are goping to bend it -- copper age hardens
Ferg
posted on 30/5/04 at 08:23 AM Reply With Quote
The microbore benders do tend to flatten the pipe if they push down rather than slide 'round. Certainly cleaning the former part of the bender helps, greasing it is good.
posted on 30/5/04 at 09:04 AM Reply With Quote
0.6mm sounds thick. Did you get it from a plumbing supplier? Could you use compression fittings on it instead of bending? might be easier and could give a decent result.
http://www.indanc.com/brass-compression-fittings-01.htm#equal_elbow
Not too bad pricewise either, you'd not need many.
[Edited on 30/5/04 by Peteff]
theconrodkid
posted on 30/5/04 at 09:42 AM Reply With Quote
i used the plastic stuff from a fiat uno
who cares who wins
pass the pork pies
Ferg
posted on 30/5/04 at 11:37 AM Reply With Quote
Hmmmm....
Microbore pipe from plumber's merchants is Table W Copper. Theoretically this isn't so good with conventional compression fittings which are designed for Table X.
posted on 30/5/04 at 02:33 PM Reply With Quote
It's not carrying high pressure gas or hot liquid so I don't think he's going to have a problem. Can you explain the difference between the two and why it's unsuitable? The marine institute seems to think it's o.k. to use them by the way.
Fixed Pipework should be made of either solid drawn Copper tube made to BS 2871 pt1 table W, X, Y, Z, (now EN1057)
All joints and unions should be kept to a minimum as the less joints, the less potential sources of leakage. They should be readily accessible for visual inspection and should be of the compression type not soldered.
Mark Allanson
posted on 30/5/04 at 06:06 PM Reply With Quote
I think I'm going to flip a Uno in the local scrappy, this microbore is so fraglie, I don't think I would feel safe driving. You can flatten it between finger and thumb!
Thanks for all the answers though
Mark
(Syd - still taking it all in, will email when understood!thanks)
theconrodkid
posted on 30/5/04 at 08:07 PM Reply With Quote
mark,the uno runs inside the o/s sill,found that out welding one up
who cares who wins
pass the pork pies
Mark Allanson
posted on 30/5/04 at 08:17 PM Reply With Quote
Yes, been there, NEARLY done that!
NS Dev
posted on 31/5/04 at 08:04 AM Reply With Quote
Ahhh, like the straightener idea Syd! Was that two rolls one side and one the other with an adjuster to alter the pressure on the third roll? Might have a go at that, would look neater in the end!
Yes, I use the 5/16 copper-nickel that you mentioned as well (have never actually used microbore though that's not to say there's owt wrong with it!!) the benefit of the copper nickel is that it doesn't work harden so fast (and it's stronger but that doesn't really matter in this instance)
[Edited on 31/5/04 by NS Dev]
mad4x4
posted on 9/6/04 at 09:54 AM Reply With Quote
I used rubber fuel hose and run it inside the tunnel with pclips. (8mm)
Scot's do it better in Kilts.
stephen_gusterson
posted on 9/6/04 at 10:25 AM Reply With Quote
so did I eventually. Some say that it will leak fumes into the tunnel, but mine isnt doing that. Plus I recon a right breeze is gonna go down the tunnel during driving anyways!
atb
steve
Terrapin_racing
posted on 9/6/04 at 11:18 AM Reply With Quote
I use these guy's
http://www.thinkauto.com/
lots of choice
or if your flush
braided stainless from
http://www.speedflow.co.uk
[Edited on 9/6/04 by Terrapin_racing]
James
posted on 9/6/04 at 12:16 PM Reply With Quote
I bought the plastic coated aluminium stuff from Tifosi. God knows why as it cost a bloody fortune!
Bends well and looks nice though!
James
