Bumble
| posted on 3/8/10 at 09:06 AM |
Front Spring ratings........
Hopefully someone can help me......
I have Protech adjustbale shocks all round but can't get decent ride height at front as springs not up to the job. I have no idea what they are
rated at but they are 8" in length. I need to get some 9" springs but what rating would you recommend for front springs on a CEC
(Zetec)?
Thanks.
richardlee237
| posted on 3/8/10 at 09:10 AM |
Mine are 9 inch with 340lb per inch
Engine is crossflow
Hope this helps
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
scoop
| posted on 3/8/10 at 09:28 AM |
Ive got some 9 inch springs rated 250lb if your interested. They should be enough for your car. I take it you want to lift the front?
procomp
| posted on 3/8/10 at 09:35 AM |
Hi
First question. Do you have an original MK locost book chassis or an MK indy chassis. I have been through you pic's and think it is a original
book chassis not an indy. There's a difference in poundage's required due to the indy having the dampers at that silly angle and inboard
from the outer joint.
If it is a book chassis then 300Lb is about right for road with a few track days but if doing more track than road work then 350Lb. Those will get you
right into the ballpark but may want moving up or down by 20-30 to suit individual application. But you will need to be pushing on at a fair old pace
before you start worrying about 20Lb here or there.
Second question is what is the open length of the dampers fitted. ?
Cheers Matt
interestedparty
| posted on 3/8/10 at 10:01 AM |
that aint no Indy, main feature of Indy is independant rear suspension
procomp
| posted on 3/8/10 at 10:35 AM |
Hi
Lol that's true. But you would be amazed as to what has been done by some at the front end in terms of book setup which had the Mk wishbones
failing. Or modded to indy style setup. Never take things for granted.
Cheers Matt
Bumble
| posted on 3/8/10 at 12:15 PM |
It's an early MK book chassis with live rear axle.
Open length of dampers is 185mm (7.25" .
procomp
| posted on 3/8/10 at 12:22 PM |
Hi
I take it that dimension is at ride height with car sat on the ground.
whats the bolt centers of the front damper when the chassis is jacked up so the wheels are hanging free clear of the ground. should be something like
12" - 13".
And what size wheels and tyres. And whats the height under the front chassis rail. ( before jacking the car up )
Cheers Matt
Bumble
| posted on 3/8/10 at 12:54 PM |
Hi Matt,
Doh.....silly me. Ignore previous dimension. With car jacked up and wheels off the floor the dimesnion is 12" between bolt hole centres.
It's 8.5" where the spring would sit.
Wheels are 195/50/15 and with car sat back on the deck theres 4" to underside of bottom chassis rail.
Thanks,
Matt
PS - how's the ankles.
quote: Originally posted by procomp
Hi
12" - 13".
Cheers Matt
procomp
| posted on 3/8/10 at 01:07 PM |
Hi
A 12" unit would normally run a 7" or an 8" spring max. I can only presume you have a very low poundage spring that needs
compressing up quite a distance to hold the car up at desired ride height. Do you have any idea of current spring poundage. ?
Virtually all book chassis run with either 12" or 12 1/2" open dampers with 7" or 8" springs the only trouble with 7" is
that there is sometimes the possibility of them being slack when in full droop and needing the thin helper springs to locate the spring on the damper
collars.
Cheers Matt
Bumble
| posted on 3/8/10 at 01:23 PM |
No idea of current spring poundage......even with springs wound up lots, it's not sufficient to hold the car at the desired height.
What poundage would you recommend?
Thanks,
Matt
procomp
| posted on 3/8/10 at 01:25 PM |
Hi
As explained in first reply ^^^. Somewhere around 300Lb - 350Lb depending on application / usage.
Cheers Matt
mangogrooveworkshop
| posted on 3/8/10 at 05:57 PM |
Theres is a pair of 325 springs here foc just pay the posty
Bumble
| posted on 3/8/10 at 08:05 PM |
Mango.....You have U2U.....
