INDY BIRD
| posted on 19/12/10 at 02:42 PM |
tilting scissor lift for sale
Type 7 or full size car Tilting Scissor Lift for sale, virtually new, approx 6 months old hardly used
This lift cost new £460 from the importer in Manchester, its a great bit of kit. It is setup for the width MNR so set narrow, it has all the bars
needed to take a full size car. It will lift 1500KG, it uses a worm gear to move the scissor lift up and down, it has rubber pads on the bits that
push up against the floor. The maximum height is 585mm off the floor, and the cool facility for tilting it means you can lift your car really high,
then tilt it.
collection only as its very heavy although has nylon castors to move around
Will fit in a medium size hatchback.
All complete and working fine.
Price £300 great xmas present
link
http://www.cjautos.site90.net/3in1.html
u2u if interested
jeffw
| posted on 19/12/10 at 05:17 PM |
Tempted...bit close to Christmas though.
scudderfish
| posted on 19/12/10 at 05:22 PM |
Dibs!
https://vetuner.co.uk
INDY BIRD
| posted on 19/12/10 at 06:29 PM |
prov sold to scudderfish,
cheers
gixermark
| posted on 19/12/10 at 09:10 PM |
looks like a handy unit...
roughly how long would it take to get the car up to max height using a drill to drive teh worm gear ?
I assume you can slide the unit under the car, rather than having to drive over it - the 150mm clearance sounds tough...
great idea...... always wanted a handy car lift..
INDY BIRD
| posted on 19/12/10 at 09:48 PM |
hi yes slides under the car yep no probs,
with electric drill not to long to get up,
with a wrench or the handle with it it take around 30secs to max height,
its a cool bit of kit and handy for builders of cars or just maintenence.
gixermark
| posted on 19/12/10 at 11:19 PM |
cheers - definately looks like a good product
