IainL
posted on 22/1/11 at 11:57 AM |
Wiring a Start Button
Has any one got a simple diagram to show how the connect up a start button when you have an ignition switch.
Which ignition switch do I buy if I want to use a start button?
IainL
speedyxjs
posted on 22/1/11 at 12:23 PM |
I sent the ignition 2 terminal to one side of the start button and the other side of the start button to the solenoid.
RazMan
posted on 22/1/11 at 12:28 PM |
You can have both ignition switch and starter switch if you wish. I've got a standard Sierra ignition switch and a Savage starter switch wired
in parallel so I can use either one depending on whether I am in or out of the car.
Raz
MakeEverything
posted on 22/1/11 at 12:53 PM |
Why not have the key and button to start? What thief would figure that out in a hurry? Turn for ignition, turn for start and press button.
Kindest Regards,
Richard.
