roadrunner
| posted on 29/1/11 at 09:34 PM |
VAG 1.8t sludge
Whats the best way of removing the sludge build up from the breather pipes in my Passat 1,8turbo. The car seems a bit heavy on fuel, so removed the
breather pipe from the cam cover to air intake pipe to find that it was sludged up to buggery. I also found that the rubber T piece from the cam cover
was shot to hell also, I guess that wouldn't be doing my fuel economy any good.
Brad.
scudderfish
| posted on 29/1/11 at 09:38 PM |
Sorry I can't help it, but I snigger like a schoolboy at a post titled 'VAG sludge'
Blow it through with an air hose? If it is oil, then soak it in an emulsifier? (Fairy Liquid)
mookaloid
| posted on 29/1/11 at 09:39 PM |
I think I would invest in new pipes - the current ones are likely to be in poor condition which could lead to problems like bits falling off inside
and collapsing.
Russell
| posted on 30/1/11 at 08:47 AM |
I've cleaned out the sump bowl and rocker cover from one of these engines that was mildly sludged. That black stuff is an absolute bu99er to
remove and I had to resort to cleaning the sump with a wire brush because nothing seemed to dissolve the crud. I tried meths, white spirit, cellulose
thinners, Gunk, even Cillit Bang. I would image that if you find anything powerful enough to dissolve the sludge it will also make short work of the
pipes.
Better get some new ones, I'm afraid...
I'm a bilingual illiterate. I can't read in two languages.
RazMan
| posted on 30/1/11 at 10:48 AM |
I hear that soaking the offending items in diesel fuel works quite well.
Raz
