JeffHs
posted on 12/2/11 at 12:44 PM |
Clutch centring tool
Does anyone know the diameter of the standard gearbox input shaft? (Pinto type 9 etc) Or the internal diameter of the spigot bearing? I'm
turning up a mandrel for centring the clutch before I take it to bits.
mookaloid
posted on 12/2/11 at 12:59 PM |
I've always done mine by eye - never had a problem
big_wasa
posted on 12/2/11 at 01:21 PM |
its a 1" 23 spline, So you want 1" minus twice the depth of the splines.
JeffHs
posted on 12/2/11 at 01:37 PM |
Yes agree with that, large dia to match splines is .91 inch or 23.2 mm. I need the smaller dia of the input shaft, it's about 5/8 inch or so
from memory
jonesier1
posted on 12/2/11 at 05:19 PM |
by eye..
im in my own little world...its ok though they know me there
Bare
posted on 12/2/11 at 06:03 PM |
Either use a Socket of the right external diameter as the Input shaft. V likely there is one in your toolbox, failing that, a bit of wooden dowel.
You are only looking to cenralise the clutch disc while tightening the pressure plate nuts.
owelly
posted on 13/2/11 at 10:44 PM |
The thinny bit of the input shaft is 15mm.
http://www.ppcmag.co.uk
