edsco
| posted on 15/3/11 at 02:20 PM |
Battery box
Hello,
Does anyone know of a supplier that sells battery boxes to fit an Odyessy PC680 battery? Dimensions(mm)
185 x 79 x 170.
I am wanting a free standing ally box with a securing clamp on top for easy access and removal or something of that nature. I have seen similar type
boxes on ebay, but the dimensions are toooo big and don't have enough room to fit a bigger box in, in the space i have available.
What i don't want is just a simple wrap around to which you can bolt to a piece of bodywork as i don't have the locating space in the
engine bay.
edsco
YQUSTA
| posted on 15/3/11 at 02:35 PM |
That is a really odd size battery to buy a standard box. Where are you going to put it if you can't screw it down???
BATTERY BOX FOR CHOP,CUSTOM OR STREETFIGHTER. on eBay (end time 10-Apr-11 18:51:38 BST) guy might be able to help.
I have not had any dealings with the seller so cannot confirm good or bad service but he says he will make to size.
I make my own to fit in the footwell very easy to do.
HTH
"If in doubt flat out"
Colin McRae
ashg
| posted on 15/3/11 at 03:21 PM |
funny that your asking about this as im in the same boat.
rally design do this one http://www.rallydesign.co.uk/product_info.php?cPath=692_1363&products_id=13602
which fits their redtop 25 battery that is (LxWxH): 182x77x168mm
i want one without the wings on the top but it may be ok for you.
[Edited on 15/3/2011 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
| posted on 15/3/11 at 03:51 PM |
It might be more sensible to look for a plastic/GRP box.
MakeEverything
| posted on 15/3/11 at 04:36 PM |
I have the same odyssey battery, and plan to just make a clamp from two long bits of studding, a few nuts and washers, and a piece of ally.
Kindest Regards,
Richard.
edsco
| posted on 15/3/11 at 04:47 PM |
Makeeverything....yeah i think that is probably what i'll end up doing. Its one of three design i was considering. Unless i got my dims wrong
the box rally design do is just a fraction too small and i dont want to blow the best part of £30 finding out really.
edsco
MakeEverything
| posted on 15/3/11 at 05:34 PM |
Give me a shout if you get stuck.
Kindest Regards,
Richard.
ashg
| posted on 15/3/11 at 07:18 PM |
the dimensions i gave are of the rd battery. the battery box is slightly bigger. the PC680 fits in the rd battery tray. i know because i took mine
down to rd and tried it. i just didnt like the wings on the top as they rubbed against my boost pipes. im going to make one on the weekend from ali
that is similar but less bulky. if you want i can take a picture of it once it is made and and if you like i will make another for you for the cost
of the materials and postage.
norfolkluego
| posted on 15/3/11 at 07:51 PM |
Exactly what I've done, OK I went a bit mental and used a piece of (small) box section instead of ally, satisfies the MSA scrutineers so it must
be good
[Edited on 15/3/11 by norfolkluego]
edsco
| posted on 15/3/11 at 10:44 PM |
Ashg...I'd be interested seeing the results of your endevours making one. Might have a comission job on your hands!! Can u send a pic when ur
done?
edsco
ashg
| posted on 17/3/11 at 07:30 AM |
yep will do.
ashg
| posted on 18/3/11 at 10:51 PM |
Pictures as requested. Still need to make the retaining strap but you get the idea
[Edited on 18/3/2011 by ashg]
ashg
| posted on 20/3/11 at 10:59 PM |
Finished off the battery box tonight. Its not the prettiest thing in the world but its functional and weighs next to nothing. lined it with foam to
hold it nice and tight.
