Author: Subject: fog and reverse lights
whitstella
posted on 9/7/11 at 06:41 AM Reply With Quote
can you recommend me the best option for fog and reverse lights?????
cheers steve
RichardK
posted on 9/7/11 at 07:29 AM Reply With Quote
1 red and 1 white would best I reckon
Rich
(May need a little more info on what your taste is like, flush mounted,housed, led etc)
Gallery updated 11/01/2011
chesney321
posted on 9/7/11 at 08:04 AM Reply With Quote
ha ha nice one..i bought mine from bolt on bits off ebay.
adithorp
Just remember that the Fog light has to be a specific fog light (with the correct E mark) as the lens/reflector on them gives a narrower, intenser beam than a brake light for instance. Several have failed recently for incorrect lamps (sold as fog lights in a set I believe). Also remember it has to be mounted so the lens surface is vertical, not just close or it'll fail.
Personally I like these or these. I think they look neater when mounted from behind through the rear panel than the larger more common types that surface mount on a base.
http://jpsc.org.uk/forum/
