Author: Subject: this evening I've been .....
posted on 20/8/11 at 06:48 PM Reply With Quote
....... removing the bearings in my front wheel (note the carbon fibre goodness )
Using a length of 8 mm studding, different diameter washers, a socket I made a puller to pull out the central tube and bearing, and then the other bearing.
bearings are on order but does anyone know where I can get 6704 ceramic bearings?
photo shows the different bits and pieces used.
