Author: Subject: What should I know about the Ford X-flow?
cjwood23
posted on 16/12/11 at 11:48 AM Reply With Quote
Guys,
Possibly now looking to buy a ready built car as my budget and time contraints are getting smaller all the time
Thing is my budget will only stretch to a pinto or x-flow powered car.
Now I've heard phrases like 'boat anchor' and 'paper weight' used when refering to the pinto but haven't come across much discussion on the x-flow.
Will probably be looking at a 1600 or 1700 x-flow.
Budget permitting there might be the possibility of an upgrade in the future to a more modern engine (zetec or 4-age).
Thoughs and opinions on the above please.
Thanks.
______________________
Chris
TimC
posted on 16/12/11 at 12:13 PM Reply With Quote
I like the X-flow. It has lots of character and sounds good on carbs. Sure, it's not the most powerful unit in the world but good fun.
My 1660 X-flow in a very light Striker kept up with a mate's Zetec in a more blingy Striker.
mark chandler
posted on 16/12/11 at 12:18 PM Reply With Quote
Great engines in their time, loads of cheap tuning bits and the car will provide a decent base if you want to go Zetec at a later point.
What you lose in power you gain in weight savings, it will put a smile on your face.
If you look at Locost race times these are 1300cc crossflow engines, when set up correctly will still shame much more powerful cars.
steve m
posted on 16/12/11 at 12:22 PM Reply With Quote
There relatively cheap, and very tunable to about 145bhp is regarded top end on a standard block /head
they leak oil !!
but i dont think i will ever be with out my 1660 xflow in my 7
posted on 16/12/11 at 12:34 PM Reply With Quote
The crossflow isn't a boat anchor, for a cast iron lump they aren't especially heavy. Generally not a bad old engine, but old thrashed examples tend to spew oil (and burn it) at a prodigious rate.
cjwood23
posted on 16/12/11 at 12:41 PM Reply With Quote
Cheers for the info guys.
I know Burton do loads of bits for the x-flow, but one of the cars I'm interested in has a 'rallytune' engine - and my google powers don't seem to unearth anything about 'rallytune'.
Any info on these?
Chris
adithorp
posted on 16/12/11 at 01:15 PM Reply With Quote
if you're considering a later upgrade to Zetec then a cross-flow is slightly easier as the exhaust is on the same side.
http://jpsc.org.uk/forum/
Alfa145
posted on 16/12/11 at 01:16 PM Reply With Quote
I have a nice 1600 that is +90 bored (so its about 1660ish?) Xflow. Bought the car 18 months ago with the intention of swapping asap to a zetec, but I've started to like the old thing now. Great sound, nice revvy engine and pulls like a train up to 7000rpm for such a small engine. mine puts out 101bhp at the rear wheels, approx 130ish at the fly) enough to scare me at times. And so sime and cheap to fix if it goes wrong.
Don't always believe what people tell you about an engine, unless you see receipts or the actual parts in the engine. I've nearly been caught out before by someone stretching the truth. Rallytune could be anything.
designer
posted on 16/12/11 at 01:26 PM Reply With Quote
My Dutton has a 1600X-flow in it and it's OK.
posted on 16/12/11 at 01:31 PM Reply With Quote
I drove (and destroyed) a very nice Xflow powered Fury.
Nice power, lovely noise. Obviously not going to win any MPG competitions on carbs unless you're constantly twiddling them and they do tend to use a total loss lubrication system
So make sure you've got some space for a nice big bottle of cheap (thick) oil for regular top-ups otherwise Mr Crankshaft goes spiny spiny and Mr Bearings goes "NO LIKEY!!!!!!!".
Paul Turner
posted on 17/12/11 at 02:22 PM Reply With Quote
Had a 1860 all steel long stoke beastie in mine for many years, had a 1700 one with a standard bottom end before that. The x-flow is a super engine, never broke down once. Only problem I had was due to the machining shop I uesd (and nearly went to work for) not being capable of decking a block level. Built correctly they do not leak oil, with race pistons mine drank about 1 litre a summer, 2,000 miles.
2 Litre Zetec now, in all honesty its much better a s a road engine but I do miss the old 1860 on a track thrash, last i heard it had gone to do trackdays in France.
posted on 17/12/11 at 07:31 PM Reply With Quote
I rebuilt my x-flow before installing it - it's like working with Meccano, a really simple engine that only requires a bit of common sense to put together properly.
It also makes a really nice noise when pushed hard!
cjwood23
posted on 17/12/11 at 07:35 PM Reply With Quote
Cheers guys.
Hoping to sort a test drive out soon.
Guessing the engine is almost the same as the 1100 in my first fiesta - had fun tinkering with that.........
Chris
posted on 17/12/11 at 08:01 PM Reply With Quote
Any info on these?
Rallytune is (was?) a tuning company in Burnley, Lancashire. I have no idea if they are still going, but this pdf shows the address as
113 Hollingreave Road, Burnley, Lancs., BB11 2HU
trextr7monkey
posted on 17/12/11 at 09:50 PM Reply With Quote
One of its other names is "God's own engine"
as said above relatively simple, plenty of parts available, basic solid engineerining in a design that goes back about 45 years.
In our jeeps we much prefer the x flow to pinto as the infamous weight of the latter affects handling adversely so spoiling any gains in power, just my opinion
atb
Mike
cjwood23
posted on 18/12/11 at 03:15 PM Reply With Quote
Cheers guys.
What about converting to unleaded? Is it a case of new valves and seats?
Chris
greed1
posted on 18/12/11 at 03:49 PM Reply With Quote
It only the exhaust seats that need doing I belive
Drive it stright sideways
trextr7monkey
posted on 18/12/11 at 09:37 PM Reply With Quote
we were quoted about £70 a number of years back , but never bothered as Redex lead substitute is only 99p at Tesco and does several tanks of fuel, we will be well into space ship mileages before we use 70 bottles of the stuff
happy motoringMike
