loggyboy
| posted on 12/1/12 at 04:17 PM |
Textured self adhesive vinyl- where?
Im after some thing to cover some of the interior side panels/tunnel, somthing simple, cheap but relatively hard wearing. Id like something in a
satin/mat black but with some texture thats NOT carbon fibre style!
Somthing similar to the pinseal (i think its called) pattern below but on a roll and thinner.
1mm Black ABS Pinseal/Textured Sheet 297x420mm A3 New | eBay
any ideas?
snakebelly
| posted on 12/1/12 at 04:25 PM |
Google is your friend:
http://www.plastock.co.uk/Sheet/ABS/Pinseal/Black-c384/
snakebelly
| posted on 12/1/12 at 04:27 PM |
or here:
http://www.plasticstockist.com/ABS-Sheet.aspx
loggyboy
| posted on 12/1/12 at 04:35 PM |
Cheers, but these seem to be rigid sheets of plastic rather than self adhesive sheets. Im after something a litte more flexible.
snakebelly
| posted on 12/1/12 at 04:42 PM |
doh just realised that! looks like google isnt a friend anymore!
loggyboy
| posted on 12/1/12 at 04:44 PM |
It might just not exist - or im just searching for the wrong keywords- who knows!
snakebelly
| posted on 12/1/12 at 04:50 PM |
why not just use the plastic sheet rather than cover something else?
loggyboy
| posted on 12/1/12 at 04:52 PM |
Its to cover ally side and tunnel panels and only in cerain areas, the plastic alone would be to thin and flimsy on the tunnel, and not practical to
do the side panels.
trextr7monkey
| posted on 12/1/12 at 05:49 PM |
You can get flock covered polystyrene as used for vac forming tomake those jewellery box inserts, might feel a bit hairy though!
atb
Mike
Neville Jones
| posted on 13/1/12 at 11:46 AM |
Halfords had treadplate vinyl in the clearance aqrea recently. A bit tacky chav looking though.
loggyboy
| posted on 13/1/12 at 11:52 AM |
Yeah, defo a bit too industrial looking to, I was thinking of something like that for the floors, but wanted something more subtle for the side
panels.
40inches
| posted on 13/1/12 at 12:10 PM |
Anything here? http://www.thevinylcorporation.co.uk/
or Di-Noc architectural http://www.idsfinishes.com/gallery/ you can get samples here.
cerbera
| posted on 13/1/12 at 12:13 PM |
I managed to get some leatherette type material but with uniform pattern rather than a leather look finish to cover the center tunnel. Not self
adhesive but Ok with a tin of contact adhesive.
Might be worth having a look at your local material shop to see what they have.
[Edited on 13/1/12 by cerbera]
