racing57
| posted on 27/2/12 at 10:08 AM |
Haynes sports car book with MX5 ??
Hi i am sorry if this has already been asked/answered..
i have the haynes build a sports car book, and the ron champion book, obviously using old fords as the donors... i have had a look thorugh some of the
threads, and have noticed the mx5 mentioned a lot, can you use the mx5 as the donor on the cars/books i have mentioned..
i dont mind fiddling a bit to get the parts to fit..
thanks
designer
| posted on 27/2/12 at 10:33 AM |
These:
http://www.vodouautokits.co.uk/
do a free download of what you want.
racing57
| posted on 27/2/12 at 11:14 AM |
thats great, so basically, that is as the book with the changes to suit the mx5..
so if i got hold of an mx5 and built to that spec, how much of the car can be used ? ie running gear, gearbox, uprights etc..
i am looking at a different engine, so could i get an adapter plate for the belhousing ?
designer
| posted on 27/2/12 at 11:23 AM |
Contact them for the full details.
He is a member here (can't remember name) so there should be no problems.
racing57
| posted on 27/2/12 at 11:25 AM |
ok, thanks...
skov
| posted on 27/2/12 at 02:03 PM |
There's also the Saturn/NTS version:
http://www.saturnsportscars.co.uk
There's quite a few of us building them over on the Haynes forum.
[Edited on 27/2/12 by skov]
40inches
| posted on 27/2/12 at 02:25 PM |
Try this: http://www.saturnsportscars.co.uk/assets/Mx-5_Build_Guide-rev3.pdf
Not Anumber
| posted on 27/2/12 at 04:30 PM |
Very do able. 115bhp from the Mark 1 MX5 1.6 engine. Nice light and low engine so you can use the donor fuel injection if you want (it will fit
under the bonnet without any holes just by changing the air filter. I believe you dont even need to modify the sump. Parts easy to get, lots of
tuning options including turbo. Rear uprights from the donor can be used. Lots of plus points against a Sierra donor. You will prob need to fit a
cat due to the age of the donor and keep the lambda sensors but that isn't much of a minus. Its the option i was going to take until I bought
my MK Indy.
