Author: Subject: megasquirt triggerwheel problem
aidan46
posted on 12/5/12 at 07:01 PM Reply With Quote
I've installed a 36-1 trigger wheel on a bike engine. If I get a spark generated at the spark plugs dose this mean it is set up correctly?
big_wasa
posted on 12/5/12 at 07:12 PM Reply With Quote
No it could still be out of time.
snapper
posted on 12/5/12 at 07:20 PM Reply With Quote
To elaborate it means the VR (crank position sensor) is seeing the missing tooth, the ecu is instructing spark at a reference to the map.
What you must be sure of is that the missing tooth is 90 degrees after TDC from there you set the spark map
If you have a spark that's a good start.
I eat to survive
I drink to forget
aidan46
posted on 12/5/12 at 07:31 PM Reply With Quote
Yes, I think I have the degrees before tdc set right, but dose the fact I'm getting a spark mean the ecu is reading the 36_1 wheel correctly?
matt_gsxr
posted on 12/5/12 at 08:20 PM Reply With Quote
Have you got a laptop talking to the megasquirt?
If so then you should see some RPM on the laptop (running tunerstudio, or megasquirt software).
Spark is a good sign though.
big-vee-twin
posted on 12/5/12 at 10:14 PM Reply With Quote
The VR sensor should be 80 degrees not 90 using a 36-1 wheel.
See this link
http://www.triangleltd.com
MakeEverything
posted on 13/5/12 at 09:37 AM Reply With Quote
See this link
Depends where it's mounted. It can be anything as long as the software settings are correct to identify the offset.
Kindest Regards,
Richard.
aidan46
posted on 13/5/12 at 09:52 AM Reply With Quote
Thanks lads had it mounted arseways!. Missing tooth was 220 degrees before sensor designated tooth.!
