Author: Subject: Type 9 Gearbox extension.
stevem427
posted on 24/5/12 at 04:20 PM Reply With Quote
Hi. A quick question. Ive just received my gear stick extension from Ben. (cheers mate). Ive just knocked out the plate on the back of the box so i can fit it. Question is what do i do with the big hole it has left by removing the plate. Cheers Steve.
deezee
posted on 24/5/12 at 04:33 PM Reply With Quote
I've left mine open. Not really a lot you can do with it.
posted on 24/5/12 at 04:38 PM Reply With Quote
Depends on what sort of gearshift extension you've got. With mine, I just drilled a hole to let the shaft through.
It's not a big problem, as it's effectively an open space anyway - no oil or grease to contain. Any dirt or grit that gets in may cause wear, but if you take the gearshift off once a year and clean & lubricate it then there's unlikely to be any trouble.
laptoprob
posted on 24/5/12 at 05:56 PM Reply With Quote
Mine too and everybody else i know
stevem427
posted on 24/5/12 at 06:01 PM Reply With Quote
Cheers for the replies chaps. I will leave it open then. Steve.
Ben_Copeland
posted on 24/5/12 at 06:02 PM Reply With Quote
Glad you got it ok mate.
Ben
Locost Map on Google Maps
Enter Your Details Here
stevem427
posted on 24/5/12 at 07:14 PM Reply With Quote
Hi Ben. Looks a good bit of kit. Cheers Steve.
