Author: Subject: Diff confirmation of ratio.... Help
jossey
posted on 1/7/13 at 05:23 PM Reply With Quote
Just bought a new 3.38 prop and off to collect on Thursday.
Am I right in thinking the easiest way to check it is what it says it to turn the prop side 1 turn and the shafts should turn 3.38 times ?
It's not on a car so it should be easy?
I don't want to strip it down the plate says its a 3.38 7" but that could be a fake n 3.38 diff's ain't cheap
Dj
David Johnson
mark chandler
posted on 1/7/13 at 05:30 PM Reply With Quote
Lock one output shaft, the other will turn 6.72 turns to one pinion turn.
When I got my 3.14 I took some splined ends to do exactly the same thing.
r1_pete
posted on 1/7/13 at 05:41 PM Reply With Quote
3.38 turns on the prop equals 1 turn of the wheels,
so,
lock one output flange, 6.76 turns of the input equals 1 turn of the free output.
jossey
posted on 1/7/13 at 05:49 PM Reply With Quote
Thank you both.
David Johnson
