Author: Subject: Drive shaft's 2
jacko
posted on 23/7/13 at 01:48 PM Reply With Quote
Drive shaft's 2
I have lobo bolt on shafts and when i hold the inner lobo i can feel a clicking tapping noise will this be the lobo or the diff causing this ?
Also to any one that has had drive shafts lobo's wear was it the inner or outer that wore
Jacko
loggyboy
posted on 23/7/13 at 02:19 PM Reply With Quote
Lobro and when you say 'when you hold it' what do you do to cause/feel the tapping.
Mistral Motorsport
jacko
posted on 23/7/13 at 03:02 PM Reply With Quote
Whats a [R] between friends
I lay on the floor hold the lobro's and move the car back and forward very slightly
Grimsdale
posted on 23/7/13 at 03:07 PM Reply With Quote
i can feel a bit of play between the joint and splines on mine - unbolt the shaft and see if you can find where the play is coming from. Don't think there's much that can be done / worth worrying about with play of the splines.
jacko
posted on 23/7/13 at 03:16 PM Reply With Quote
Im willing to buy new drive shafts if i can confirm its the shafts and not the diff
mcerd1
posted on 23/7/13 at 03:26 PM Reply With Quote
I think I've still got a spare pair of used 100mm CV's if you want them ? (postage could be a killer)
loggyboy
posted on 23/7/13 at 03:30 PM Reply With Quote
Un bolt the shafts then rock the input flanges to see if you can still feel the movement.
If you can its the diff. (if the prop stays still)
Mistral Motorsport
madteg
posted on 23/7/13 at 06:33 PM Reply With Quote
I am having a very similar problem, fitted three diffs and now i am sure the knocking i am getting is not the diff.
Have fitted new lobo joints to old shafts but still got play on the shafts. I checked for play on a friends push in drive shaft and there is none at all. Have put it down to the lobo shafts should have some play in them but the rubber coupling on the prop stops the knocking. As we have no rubber coupling we have no shock absorption. Hope this makes sense.
jacko
posted on 23/7/13 at 07:28 PM Reply With Quote
Hi its a long story it goes something like this
http://www.locostbuilders.co.uk/viewthread.php?tid=183265
I have been getting a knocking noise for a long time now and i have found it to be the gearbox mounting a new one is fitted and its stopped the bad knocking except i have a small knocking on the drive shafts i think which i want to stop and that's what this post is about
any help much appreciated i WILL get to the bottom of it
Graham
