Author: Subject: 'Tuning' an exhaust correctly
jps
posted on 2/9/13 at 02:44 PM Reply With Quote
I'm no expert - but it's my understanding that the airflow OUT of the engine can be as important as the airflow IN to an engine. I.e. there will be an ideal length/diameter to an exhaust system, an ideal way in which the exhaust manifold combines into the silencer(s), an ideal amount of 'resistance' in a silencer, etc.
But from reading a few threads it seems a common attitude is sort of "get the pipes together, get them out of the side of the car where it looks nice, pick a silencer that looks good, job done"...
Where can I find some good info on how to do it 'right'? Or, with a 1.6 Pinto going into my build - and not being too bothered about masses of power - do i just go with the 'looks good, job done' approach?
carlknight1982
posted on 2/9/13 at 02:55 PM Reply With Quote
id be more worried about the noise level for IVA to start with,
Logic will get you from a A to B
Imagination will take you everywhere.
Bluemoon
posted on 2/9/13 at 02:58 PM Reply With Quote
Most people seem to take that approach including some kitcar manufactures (and myself!!). It is possible to tune the exhaust there are forumla's out there to work out the lengths of pipe in the header to increase "scavenging", difficulty for an amateur is finding out if you have made a difference you really need use a rolling road before and after to see what effect you have have..
http://en.wikipedia.org/wiki/Exhaust_manifold
[Edited on 2/9/13 by Bluemoon]
loggyboy
posted on 2/9/13 at 03:02 PM Reply With Quote
As youy say its not just air getting in, its getting out - but its also getting it through, so unless you are doing inlet AND head/cam work AND exhaust, the total gains you can make with an exhaust are nominmal to minimal, you might get a few hp,
Gains are almost defautly made over a standard pea shooter system with a tight cast manifold. Stick a four branch on (standard for these cars 90% of the time), followed by a 4-2-1 or 4-1 which ever your preference (generally 4-1 = boost of high end power, 4-2-1 = more mid range power - but of course theres always exceptions), add a decent silencer to get yout though trackdays/iva/past policeman - what ever you need. Equal length headers shows good design, but its not always (easily) possible and again, gains are minimal.
As with most mods, its about adding lots of little gains to get a large gain.
However spending lots of money and time getting a well designed manifold for boat anchor engine may seem a lil silly to some.
Mistral Motorsport
jps
posted on 2/9/13 at 03:21 PM Reply With Quote
Cheers chaps - as always some good info!
The reason i'm thinking about it is:
a) i've got to fabricate something as it is - my pinto will be low power output anyway - i don't want to strangle it even more if there is a 'wrong way' which I can easily avoid with some research
b) the long term plan is to replace with another engine years down the road - I don't want to exit in completely the wrong place now - and find that when I swap engine in the future I have to remove the side panel if i've gone out there when i would have been better going out over the chassis rails / side of the bonnet first time round anyway, or vice versa...
MakeEverything
posted on 2/9/13 at 03:58 PM Reply With Quote
Bell, A. G., 2005. Chapter 16 - The Exhaust System. In: Forced Induction Performance Tuning. Yeovil: Haynes Publishing, p. 464.
and
Bell, A. G., 2011. Chapter 9 - The Exhaust System. In: Four Stroke Performance Tuninig. Yeovil: Haynes Publishing, p. 478.
Both offer calculations on runner sizing and lengths etc. amongst other things.
[Edited on 2-9-13, by MakeEverything]
Kindest Regards,
Richard.
designer
posted on 2/9/13 at 04:30 PM Reply With Quote
Exhaust tuning is a science and you can't tune an exhaust to be efficient at all rev. ranges. Tuning depends upon use.
snapper
posted on 2/9/13 at 04:33 PM Reply With Quote
If you are running a standard cam any 4 branch will help
Proper tuning includes intake length as well as exhaust and will be based on your cam
I found that the Robin Hood manifold from 1997 was pretty close to perfect for my RL31 cam and just needed the collector enlarging and extending
I eat to survive
I drink to forget
mark chandler
posted on 2/9/13 at 05:24 PM Reply With Quote
I cannot recommend this book enough
I purchased it years ago, it teaches you that a little of everything gives the best results.
I had a 2.0 litre Capri, standard cam and carb, 1/4" off the head, ports shaped using bells principles and cut the valve seats out, 4-2-1 exhaust, just took time building it up carefully and dialling in the cam. On the rollers it was 4bhp less than my mates 3.0litre Capri, same day same rollers ~ 130 BHP.
Regards Mark
[Edited on 2/9/13 by mark chandler]
snapper
posted on 2/9/13 at 05:34 PM Reply With Quote
1/4" off the head?!?!
That's 6.35mm
2.5mm would give 12 to 1
I eat to survive
I drink to forget
Canada EH!
posted on 2/9/13 at 05:43 PM Reply With Quote
There is a well known bike header manufacturer here in Canada who holds a PHD in music, speaking of tuning exhaust systems
mark chandler
posted on 2/9/13 at 07:06 PM Reply With Quote
That's 6.35mm
Humm thinking about it 60 thou, I had 1/4" taken off my landrover head as it was 8:1, something low like that.
macc man
posted on 2/9/13 at 08:06 PM Reply With Quote
With most 7 type cars the exhaust is a compromise between what will fit the limited space available and looks. I made my 4 into 1 system to fit rather than to be super efficient. I was happy with the result and plenty of power too.
Slimy38
posted on 2/9/13 at 09:11 PM Reply With Quote
I have to admit that's what I'm expecting on my build, I will be more interested in getting the pipe to the back of the car than anything too fancy. Even the choice of a 4-1 or 4-2-1 will be determined by the space in the engine bay.
ettore bugatti
posted on 2/9/13 at 11:35 PM Reply With Quote
Apparently, PipeMax is a great tool to figure out the dimensions.
This should give some ballpark figures:
http://www.mez.co.uk/mezporting/exhaust_length.html
In general, dimensions are defined/constrained by:
- engine spec (intake, head, cam)
- available room
- focus on peak power or peak torque
and found some more info:
http://www.turbosport.co.uk/showthread.php?t=151004
