posted on 20/12/13 at 12:52 AM |
FS: Engines, Gearbox, Throttle Bodies, Bellhousing, Etc
45 THROTTLE BODIES
TWM / Borla 45mm TB's, air horns, linkage and fuel rail.
For DCOE pattern manifold.
Previous owner ground down the injector collars so he could fit shorter Pico style injectors (see second pic). I can supply a set of IWP 042 injectors
for an extra fiver. As far as I'm aware, the longer injectors will still fit and seal fine.
Comes with linkage, but no throttle cable bracket.
No TPS fitted (see third pic). Takes a 'clockwise' one.
Someone has ground away at various points on the bodies for bolt clearances (see last pic). Does not detract from the functionality of the
TB's... just want to be absolutely honest.
£295 please (UK delivery at a fiver).
REBUILT C20XE RED TOP ENGINE
Stripped and fully rebuilt as follows...
Block bead-blasted
Bores honed
Deck skimmed
New piston rings
New main bearings
New big-end bearings
Block painted
Head acid cleaned
skimmed
Valves reground and cleaned
New oil seals
Distributor alloy blank
New gaskets.
New Gates belt and tensioner kit
New sump
New stainless sump bolts
Rocker cover breather mod
Rocker cover powder coated
New stainless rocker cover bolts
New manifold studs and bolts
Timing Belt cover powder coated
New HT leads
Coil pack and mount
OE flywheel lightened
£895 please and I will throw in a set of new ARP con-rod bolts / paste (not fitted).
Is curently bolted into a small frame, so can be delivered securely on a pallet (UK mainland) for £65.
XE TO TYPE 9 SBD ALLOY BELLHOUSING & SUNDRIES
All unused.
Short - vertical.
With new SBD gasket, SBD bearing, clutch-arm and SBD bellhousing to engine block bolts. Would cost around £210 from SBD (not including the clutch
arm).
£140 + £10 UK mainland delivery from me.
MX5 ENGINE AND GEARBOX
Engine and 5 speed gearbox from a 2005 MK2.5 (VVT).
Comes with alternator, starter, plugs / coils, flywheel and clutch.
I can supply the inlet / throttle body assembly and exhaust manifold if you would like them (both are removed from the head - I don't have the
gaskets or bolts).
The car has suffered rear damage and was written off at 55k miles.
I paid a premium for it because the age and mileage information was verified before sale.
Only asking £395 as I need the space! UK mainland delivery can be arranged at £65.
It's Evolution Baby!
posted on 2/1/14 at 07:03 PM |
2014 bump!
posted on 3/1/14 at 06:42 PM |
THROTTLE BODIES AND BELLHOUSING PARTS SOLD
rdodger
posted on 6/1/14 at 04:14 PM |
Hi
Would you sell the MX5 inlet manifold separately?
posted on 6/1/14 at 04:24 PM |
I would indeed. I'll pm you in a min
posted on 8/1/14 at 05:46 PM |
REDUCTIONS
XE engine now £800 (I won't be going any lower!).
MX5 kit now £295.
StevieB
posted on 8/1/14 at 06:03 PM |
One of these days I'll have some money to hand when you're selling an engine!
That engine would sit really nicely in place of my CVH lump as well
dave
posted on 8/1/14 at 08:33 PM |
Dont suppose you have a westfield fuel tank kicking about you dont need? Injection type.
posted on 8/1/14 at 09:23 PM |
'Fraid not Dave.
Ryegault
posted on 15/10/14 at 01:36 PM |
Is this still available? Thanks
posted on 15/10/14 at 03:23 PM |
Fraid not - all went some time ago. Apologies for not closing the thread.
