Author: Subject: Bleed nipples and IVA
prawnabie
posted on 18/5/14 at 11:16 AM Reply With Quote
Hi everyone.
As I am not happy with the fact that Westfield expect you to put the brake light switch in the rear brake line, I have opted to make a pedal box mounted bracket to mount the donor MX5's electronic switch.
The trouble is the Westfield brake lines are cut to size, so I have a t piece mounted to the chassis that used to house the switch. I cannot remove the t piece as it is a mourning point for the line so can anyone see and problems with fitting a bleed nipple into the hole when it comes to IVA?
Shaun
Smoking Frog
posted on 18/5/14 at 11:41 AM Reply With Quote
I have the brake light switch in the rear brake line, works fine. Mount it on it's side or upside down to prevent a potential bubble forming. You could just fit the pressure switch and not connect it up if using a mechanical switch. The T piece could be removed and fit extra supports (not difficult). I not sure if a bleed nipple would be acceptable.
davidimurray
posted on 18/5/14 at 02:36 PM Reply With Quote
As long as it all seals then no issues.
I have my brake switch mounted sideways into a Tee, with a nipple in the top leg to allow me to bleed the sensor.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Smokey mow
posted on 18/5/14 at 02:46 PM Reply With Quote
If you're doing away with the pressure switch I would suggest replacing the 4-way tee that's currently fitted to the car with a 3-way tee.
loggyboy
posted on 18/5/14 at 04:21 PM Reply With Quote
As above, swap for a 3 way :-
Mistral Motorsport
prawnabie
posted on 18/5/14 at 07:27 PM Reply With Quote
Thanks for the replies!
The union is a 3 way already. as it bolts to a tang welded to the chassis removing it will make the mounting points before and after too far apart.
I have already done the deed but was just after confirmation it was OK to have a bleed nipple somewhere else other than a caliper for IVA.
Ta muchly
