Author: Subject: OT: DIY Boiler and Megaflow
James
posted on 14/6/14 at 10:46 AM Reply With Quote
Another plumbing question I'm afraid folks!
We want to rip out the current ancient boiler and cylinder. Both are in the wrong place, the boiler is inefficient blah, blah. We're not even allowed to have cavity wall until we have a more efficient boiler!
We'd like a unvented system type with a megaflo (or similar).
I can easily do the new radiators and the new plumbing for them. However its the rest of the system I'm a bit unsure of!
Megaflow do a 'systemfit' model where the tank has everything else already attached to it. SystemFit cylinder
I know I need a Gas Safe person to do the gas pipe (and commission the boiler?). If I bought the system fit, is it just a case of connecting up the mains, the radiators and the boiler supply?
I wonder if I could do the boiler too?
I'm not sure if it's all fairly simple of whether I've missed something obvious?
I've had a quote from a plumber to fit a new Worcester Bosch boiler (gas, flue etc.) and connect it up to the megaflo I've fitted for £2000.
My mate did one for his parents and said the cylinder came with instructions and he just followed them!
Any help appreciated!
Thanks,
James
talkingcars
posted on 14/6/14 at 11:59 AM Reply With Quote
If you understand the principles of plumbing and are mechanically able a complete heating system isn't difficult.
Unfortunatly modern regulations state that major plumbing works and electrical works have to either be installed by a trained installer who is quilified and can self certify or have to be inspected before use.
I'd speak to a few local plumbers and see who'll inspect your work, certify it for you and do the final connection.
£2k for a boiler isn't that bad, British Gas would be asking for £6k!
adam1985
posted on 14/6/14 at 06:58 PM Reply With Quote
You should be registered to fit unvented cyclinders. check out youtube for exploding unvented cylinders for reasons why
http://m.youtube.com/watch?v=61uDmQF5I2E
James
posted on 15/6/14 at 10:49 AM Reply With Quote
Yes, I know you have to be certified now, etc etc.
I've just re-wired the entire house and had it signed off by an electrician so I get that.
James
