cfc999
posted on 6/4/15 at 03:25 AM |
Autosprint 1390 Xflow Engine Package.
For sale a1390cc Autosprint xflow. Selling it as a complete package including 4 speed rocket box (standard).
The engine has only recently been installed and is due to go on my local rolling road in the next couple of weeks for a tune up. Its a very clean and
tidy installation and starts and runs.
The engine was bought new from Autosprint in Birmingham and used to sprint and hillclimb a Westfield in the early 90's in the up to1400cc kit
car class. When the class changed the engine was removed and sat in a dry garage for the next ten years. I purchased from the original owner and
decided to use it in my Sylva Striker sprint/hillclimb project.
The engine has only recently been fitted but I've decided to go down the bike engine route.I'm unsure of the exact spec but it was built
by Autosprint as a rally spec engine so its got a high lift cam, big valve head, double valve springs ect. Its a early engine so its not had the
unleaded valve seat conversion but its been run with the correct fuel additive.
Includes the following.
Twin 40 Delloto's with swan neck inlet manifold.
H&H Ignition Solution shortened race spec distributor with correct side entery cap.
High pressure oil pump.
Large capacity baffled sump.
Alloy 13 row oil cooler with sandwich plate and braded oil hoses..
Carbon dash with loom and gauges as below.
Race tech oil pressure gauge with sender unit.
Race tech rev counter
Race tech water temp gauge.
Race spec 4 into 1 exhaust manifold.
Basically everything that goes with the engine. Proberly loads more but can't remember of the top of my head.
Only interested in selling as a package and not intesested in splitting it.
If you add everything thing up I've spent over 2k. Worth more slitting but in all honesty can't be bothered.
Will take £995 for everything.
Chris
Cant seem to upload any pics so pm me with email address and I'll send them.
Please try the following link.
http://s292.photobucket.com/user/cfc999/media/Mobile%20Uploads/20150406_191326_zpsepdjtcdz.jpg.html?sort=3&o=0
[Edited on 6/4/15 by cfc999]
cfc999
posted on 8/4/15 at 05:38 PM |
Now on fleebay.
Item number 261842067741
