snippy
posted on 22/1/17 at 09:10 PM |
Steering column lower bush
I need to replace the lower rubber bush on my sierra steering column. It's the circular bush which has 4 holes where pins go through it, near
to where the column attaches to the steering rack. Mine is perished and splits are forming.
I've seen polyurethane versions but they're £60! I also understand one from a Landrovery Discovery will fit but you have to buy a complete
column and then cut the bush out. They're a bit cheaper at £30.
Surely it can be got somewhere cheaper? Anyone had experience of buying one?
avagolen
posted on 22/1/17 at 09:35 PM |
Not sure if it is the correct one, no picture shown, but Rally Design do one at £14.05
Steering column coupling (kit of 1) Superflex Bush
[SF0050K]
Might be worth a phone call.
snippy
posted on 24/1/17 at 04:11 PM |
Thanks for the info. I rang Rally Design but that one is for a Datsun 280Z.
posted on 24/1/17 at 06:17 PM |
Rally Design also sell one to suit the Ford spline, an upper joint and a steering shaft that can be altered if needed. Car Builders Solutions also
sell them . If you want just the Flexi disc try your local motor factors
snippy
posted on 13/2/17 at 07:46 PM |
So I ended up buying a Landrover Discovery lower column and then removed the rubber bush which I have now fitted to my Sierra column. Job done and at
£12 a locost solution!
avagolen
posted on 13/2/17 at 10:04 PM |
Excellent.
