big_wasa
| posted on 6/3/05 at 08:50 AM |
zetec emmissions help ?
Is there any way I can get a 1998 engine past emissions when running carbs? I want the above engine as its only done 25k from new and is only £250+vat
and its the black top....But Ive already got my bike carbs and have spoken to Bogg Brothers and got the ball rolling on my manifold......If I fit the
zetec to the sierra donor and register the engine change will this do it or will emissions still go on the age of the engine when I put it in the
locost ? It will meet emissions in the sierra because emissions will have to meet the age of the car not the engine ?
your input would be greatfully received
zetec
| posted on 6/3/05 at 09:47 AM |
The test is based on the age of the engine. if no proof of age then based on it being a new engine.
I know some bike engined cars get thru on carbs using a special cat and air bleed system.
My advice would be go for injection if you want a new engine or just get a pre"95 one, there are loads of good one about and even with 70,000 on
the clock they would still be as good as new, most will see over 150,000 miles before they start to wear.
If you want to use bike stuff then throttle bodies would be just as easy to use as you will need to run an ECU for the ignition anyway.
[Edited on 6/3/05 by zetec]
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
alister667
| posted on 6/3/05 at 10:52 AM |
I can't think of any reason you couldn't get it through emissions on carbs.
Bear in mind you'll need a cat as well.
However, it will reqire a lot of tweaking of the carbs, and a lot of time in front of an emissions analyser.
To be honest it would nearly be easier to get the loan of an older engine, get it SVA'd then replace the engine.
http://members.lycos.co.uk/alister667/
JonBowden
| posted on 6/3/05 at 12:36 PM |
Once you've got your car SVA'd with an old (pre 95) engine using high emissions, how do future MOT testers know to allow high emissions ?
Jon
stevebubs
| posted on 6/3/05 at 02:11 PM |
I think the Kitcar workshop have emissions gear you can hire/buy for SVA. Worth giving them a shout.
S
alister667
| posted on 7/3/05 at 08:19 AM |
Q plate cars do not have to do an emissions test at MOT.
JonBowden
| posted on 7/3/05 at 12:24 PM |
So, does that mean that I can install a newish engine with a cat, get the thing SVa'd, then ditch the cat and do what I like without regard to
emissions?
Jon
alister667
| posted on 7/3/05 at 04:50 PM |
emissions?
Of course not! Such a thing would be illegal.
That's the reason most folks with Bike engines rent a cat for the SVA.
