Dillinger1977
posted on 7/7/05 at 09:16 PM |
2005 r1 info?
anyone had any experience with one?
been offered one, just wanted to get the lowdown on whats different about them before i made any decisions.
by all accounts i'd need a new custom 'racing' loom to bypass the ignition security?
anything else? pros/cons?
any info appreciated
cheers,
-Rog
colibriman
posted on 7/7/05 at 09:32 PM |
they are a lot peakier than the earlier injected ones....apparently nothing much happens under 8000rpm then the world goes nuts....
so unless your going to be thrashing the nuts off it all the time, your better sticking with the 02/03 injected one....
HTH
Colin
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
ChrisGamlin
posted on 7/7/05 at 09:46 PM |
Have a browse through the DSR Forums as some of the racers there have used the 04/05 engine, but as
Colin says it is a lot peakier than the earlier engine, less power/torque than the 02/03 engine under 8k, but revs to 13.5k or something silly and
produces 20bhp more peak power
[Edited on 7/7/05 by ChrisGamlin]
Dillinger1977
posted on 7/7/05 at 10:05 PM |
ahh. not keen on the idea of a gutless bottom end so maybe i'll stick to the older ones. I was intrigued as the new ones (04/05) are only a
small bit more expensive than the old ones.. which have become like rocking horse doo-dah..
keep me posted if you get anything in colin
-Rog
colibriman
posted on 7/7/05 at 10:11 PM |
Will do Rog..
Thinking of using one myself now..want more torque...
I've been offered a busa but can't afford to drop that in my own car..
note to myself....
must sell more engines...must find more F.I R1's....
fancy a busa....It's only £3K !
tks
posted on 8/7/05 at 12:36 PM |
mhhh
could the newer emissions rulez not being an problem?
i mean cant the bottom end power no being returned using an powercommand etc.??
Tks
ChrisGamlin
posted on 8/7/05 at 05:46 PM |
Nah its generally a more revvy engine, shorter stroke and bigger pistons I think which usually has the effect of losing mid range torque but gaining
top end. Im sure you could gain some back by tuning with a Power Commander etc, but you can probably gain the ame again with the 02/03 engine, so the
gap would be the same.
Having said all that I wouldnt mind betting that under 8k the new R1 is still more pokey than a carbed blade, so it certainly wouldnt be slow in the
mid range, and would go ballistic at higher revs.
fesycresy
posted on 8/7/05 at 06:46 PM |
I would double check the motor dimensions.
I believe they are the same from '98 to '03, but I think '04 motor may vary.
I stand to be corrected, could someone in the know confirm this ?
colibriman
posted on 8/7/05 at 07:14 PM |
yes your right...the mountings are different, because it is a more angled engine it might even be a bit harder to fit in a seven...it is small though
so I could also be talking poo....
ChrisGamlin
posted on 8/7/05 at 09:59 PM |
The 98-03 R1 engine is a lot more upright than most, and with the vertically stacked gearbox its a fair bit narrower overall, so I reckon an 04 would
still be well within the bounds of regular BEC friendly dimensions.
My blade engine used to almost sit on the near side chassis rail at the front, with the prop over towards the offside about 30mm inboard from the
tunnel on the drivers side. The R1 is about 40mm away from the nearside chassis rail yet still the prop is straighter than it was on the blade, so it
shows how much narrower the 98-03 engine is compared even to a relatively small blade engine.
Chris
