colibriman
| posted on 12/10/05 at 09:49 PM |
Which exhaust wrap?
What's the best to use.. pro's and con's please.
1.5mm or 3mm thick, 25 or 50mm wide?
how much do I need for a blade manifold?
cheers
Colin
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
| posted on 12/10/05 at 10:10 PM |
ive used both 25 and 50mm, i think the 25 is better for going round corners. Ive never come across different thicknesses though. You want 50% overlap
with each time round.
Theres quite a lot of technique involved tbh, working out where best to start and how to secure it all neatly.
colibriman
| posted on 12/10/05 at 10:12 PM |
Ok...thanks Joel...
_Aero_
| posted on 12/10/05 at 11:11 PM |
About 5m of 25mm should do the trick if you are only going to the inner edge of the side panel. You need 4 jubilee clips to finish and some wire to
start...
wicket
| posted on 13/10/05 at 08:05 AM |
I used 65' of 1" wide to do my 4-2-1 X-flow manifold. It needed a lot more than anticipated, the aim was to have approx 1/2 tape width
overlap but in reality this was more like 3/4 overlap to get complete coverage, especially over the collectors and the tighter bends. Got a feeling it
may be more difficult with wider tape.
It was secured with st.st loccking wire.
