dave blissett
posted on 23/2/03 at 08:48 PM |
TRANSIT BALL JOINT TAPER
I HAVE TUREND MY STUB ADAPTORS UP AT WORK BUT CAN ANYONE TELL ME WHAT THE TAPER IS ON A TRANSIT BALL JOINT
bob
posted on 24/2/03 at 10:49 PM |
DAVE
I'm sure this has been asked before,Although i thought it was only the bottom ball joint needed a taper.
I know the bottom B/J taper goes from 12mm to 14mm if that helps
jonti
posted on 25/2/03 at 06:23 PM |
If its any help the track rod end taper on a sierra is, I'm told, 7degrees. I suppose it's likley/possible to be the same for the Tranny
[Edited on 25/2/03 by jonti]
ChrisW
posted on 25/2/03 at 06:59 PM |
7.5 from memory I'm sure 7 will do!
Chris
My gaff my rules
bob
posted on 25/2/03 at 07:38 PM |
I just checked a pilgrim build manual and they sat 7 degrees for bottom taper as well
