darrenga
| posted on 26/4/06 at 03:35 PM |
flange rivets
in the build list is says 5mm x 16mm flange rivets,i have to to a couple of places that have said they are 4.8mm not 5mm is this right or do they have
to be 5mm
| posted on 26/4/06 at 03:55 PM |
For the difference use either...
stevec
| posted on 26/4/06 at 03:56 PM |
You should get a box of them in the deluxe kit,
I did.
Steve.
darrenga
| posted on 26/4/06 at 04:03 PM |
only getting starter kit dont think you get them with that
greggors84
| posted on 26/4/06 at 05:31 PM |
I really wouldnt worry, 0.2 mm is nothing. When you start building the car you will find you worry about little things like this less and less.
Chris
The Magnificent 7!
indykid
| posted on 26/4/06 at 06:29 PM |
just make sure you use a 5mm bit. it'd be a pita to have to ream them all out a gnat's bollock hair if the 5mm rivets wont fit in a 4.8
hole!
sorry if that was obvious
tom
