Author: Subject: Rear Springs - What poundage??
TangoMan
posted on 1/5/06 at 09:51 PM Reply With Quote
I have decided that I need new rear springs. My front end feels well planted but the rear is way too stiff. Shakes yer fillings out on bumpy roads with one in but is a bit better with two.
It also suffers from oversteer, which looks great but can get interesting.
I have a live axle and have no idea what springs are fitted.
Can anyone offer advice on what springs to fit to a live rear axle on a car weighing around 650Kg.
Thanks for any info.
nitram38
posted on 1/5/06 at 11:13 PM Reply With Quote
Bumps are controlled by your shocks and not springs (unless they are really solid).
Springs handle body roll in corners.
If you have adjustable shocks, wind the stop back a bit.
TangoMan
posted on 1/5/06 at 11:15 PM Reply With Quote
Adjustable Shocks
I tried that first.
They are on the lowest setting.
Surrey Dave
posted on 2/5/06 at 12:02 AM Reply With Quote
My 1st set were !40lbs , good ride but too soft ,(kept hitting bump stops).
Now got 200lbs fitted
[Edited on 2/5/06 by Surrey Dave]
nitram38
posted on 2/5/06 at 03:57 AM Reply With Quote
Are your springs wound too tight to achieve the correct ride height?
Over compressing them can make them solid.
I made this mistake on my rear shocks, but I changed them for an inch longer and kept the springs. This allowed the springs to work properly. (not a 7 type car)
posted on 2/5/06 at 07:18 AM Reply With Quote
A lot of people have had success with 180 lb/in springs for road use
posted on 2/5/06 at 07:40 AM Reply With Quote
Roll stifffness controls body roll
Springs control suspension frequuency and bumps
Shocks (Dampers) damp suspension osscillations and are use to modify the way the vehicle responds to transient changes.
[Edited on 2/5/06 by britishtrident]
JAG
posted on 2/5/06 at 07:53 AM Reply With Quote
I have 150lbs on the back of my car.
It's a bit lighter though at 550kgs.
Justin
posted on 2/5/06 at 07:59 AM Reply With Quote
I have a similar issue...
When I had lighter springs (180lb) the ride was good on most roads but I hit the bump stops on harsh bits. If I upped the damping rate then I just got a bad ride. I fitted slightly stronger springs (200lb) and softened the dampers fully and now it's generally Ok. I manage to live with it on most roads - it's just a bit harsh on very bumpy bits!
Iterestingly, when my wife's in the car (so the load is spread fairly evenly) the ride is a lot better - maybe I need to concentrate on the setup adjustments a bit more...
Surrey Dave
posted on 2/5/06 at 08:32 AM Reply With Quote
My issue was because my rear damper mounts are not in the correct place so I have 1" less travel on the rear dampers ,when in fact you should have longer travel on the rear as the dampers are vertical.
This is an error in the book I believe.
It's one of those jobs to do that I never get round to, fit longer dampers softer springs probably around 160lbs would give a better road hugginr ride.
TangoMan
posted on 2/5/06 at 09:13 PM Reply With Quote
Time to order then
Thanks guys.
I will start with 200lb springs then to see how it feels.
I do want it stiff for track days but not so stiff that it bounces around corners.
paulf
posted on 2/5/06 at 09:29 PM Reply With Quote
I picked up a pair of 13,5 inch AVOs cheap at Stonleigh but have found that they are to long to fit to the book style mounts, I am using converted mini dampers that are 13 inch at present with 160 lb springs, but they have been bottoming out on hard bumps. I was a bit annoyed when they didnt fit but now think it will have the axle out and cut off the book type mounts and fit them to the radius arm bolt instead and add an extra plate inboard to support the inner end of the bolt.I also have some 180lb springs to fit
Hopefully this will be worthwhile.
Paul.
