Jon Bradbury
| posted on 23/4/03 at 09:39 AM |
Sierra 2.0L DOHC Carb vacuum connections
I'm having a spot of bother with the vacuum pipe connections on the carburettor on my Ford 2.0 DOHC engine. Basically I am not sure where a
T-piece on the carb is supposed to be connected. The t-piece itself was broken whilst getting the engine out of the donor but I think that it is
supposed to connect to the small vacuum inlet immediately below. Take a look at the attached picture - I replaced the tee with a lenth of pipe, and
the connection I think is required is between the two ringed points. This is (I think) a Webber DGAV carb, and it has various vacuum-operated features
which I think might require this connection in order to work properly.
Can anyone cast any light on this?
JonB
Jon Bradbury
| posted on 23/4/03 at 03:23 PM |
The carb is a Webber 2V TLD
The carb is a Webber 2V TLD, according to one of my colleagues over on the Robin Hood discussion board - if that's any use.
mad_skillz
| posted on 26/4/03 at 01:44 PM |
Ya its definitely a 2v, i have the same engine. (DOHC 8v)
Alex
stephen_gusterson
| posted on 26/4/03 at 10:04 PM |
as a last resort, if no one can tell you on here, how about a trip the the breakers to look at one there......
atb
steve
