Oliver Coles
| posted on 12/8/06 at 07:08 PM |
1974 hillman imp
Thinking of buying my first car this hillman imp which is now seriously on the cards now i have somewhere to put it.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=018&item=280016252156&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Im probably going to bid on it sometime in the next few days before i go on holiday.
Wish me luck
Only 16 and i have already had my midlife crisis
John Bonnett
| posted on 12/8/06 at 08:26 PM |
A seriously underestimated car. I had one new in 1967, it was so much fun in the snow. Handles really well and of course the engine is derived from
Coventry Climax that powered all sorts of sports cars including Lotus (and also forklift trucks I believe). I think the only weakness was a tendency
to blow head gaskets. The 997cc Rallye Imp had good results on the Monte Carlo.
Best of luck with the Auction, I hope you get it.
John
| posted on 12/8/06 at 11:16 PM |
I wouldn't go too mad on it. I welded a few of those and helped fix the head gaskets and that was when they were not so old. If you don't
get a look round it first be prepared for some work.
peterriley2
| posted on 12/8/06 at 11:19 PM |
out of curiousity how much are you willing to spend on it? im guessing this is the new contender for your first car, personaly id choose a mini but
the imp does look very cool and has a great deal of style!!
Joel
If you dont respect yourself, dont expect respect from anyone else
Live your dreams, dont dream your life
Women only want you for one thing- everything!
| posted on 13/8/06 at 05:41 AM |
What kills Imps is rust in the area of the body adjacent to the rear subframe/trailling arm mounts and rear spring pads, first sign is the car usually
sits low at the back
Check the front wishbones for rust --- now unobtainable.
Check it isn't jumping out of any gear.
Check the front king pins --- can be a swine of a job. no longer available but new batch has been manufactured for the pwners club.
Check steering rack for wear --- unique part and can be quuite wear prone, also check the steering rack gaitor again unique part no longer available
although repro ones might be now sold.
Oliver Coles
| posted on 13/8/06 at 07:28 AM |
thanks for the advice. As far as a mini is concerned, A) they apparently rust worse than imps because they are made of thinner gauge steel and B) my
feet are to large to operate the pedal .
spunky
| posted on 13/8/06 at 09:38 AM |
have to reply
I've had a few Imps over the years, they are fabulous little cars and as a first car you cant really go wrong. Simple mechanics (you can drop
the engine in 30 minutes) sweet handling, and a lot more style than a mini. Plus, although it will never be top of the classic car wish list, keep it
standard and tidy, and your not gonna lose money on it.
As BT says the rear subframe is the killer, this looks like a pretty good example. I'm getting all nostalgic, might have to put a bid in
John
The reckless man may not live as long......
But the cautious man does not live at all.....
| posted on 13/8/06 at 12:23 PM |
At least with a mini they don't blow head gaskets every five minutes ,Drive shaft couplings don't fail as often (not at all on the post
1970s) you don't need a bag of sand in the boot to make them handle ,all mechanical parts are still available as are body panels . All round
they are more reliable AND cheaper to run.
froggy
| posted on 13/8/06 at 03:44 PM |
i have to say my abiding memory of my imp was doing the head gasket and roto couplings, not the driving experience apart from lifting the inside front
wheel a couple of times round roundabouts
| posted on 13/8/06 at 04:05 PM |
Perhaps Oliver would be better of with a Reliant Kitten , small engine, economical and probably cheap to insure ? If he can find one?
Oliver Coles
| posted on 14/8/06 at 01:15 PM |
I was looking at reliant kittens but i do want somthing with a little bit of go and something that won't crumble if hit by another car. Imps
were quite safe cars for there time
| posted on 14/8/06 at 06:31 PM |
Having driven Reliants 3 and 4 wheeled in the past, although I've never owned one I thought they went pretty well . 850cc Robins accelarate as
well as the old Mini Cooper . Have a friend who rolled his Regal van across six lanes of the Newmarket bi-pass before there was crash barriers . He
got out , changed the spare wheel and drove home We checked the car including the chassis for damage and apart from scratch marks the drivers door
handle was broken .Reliants have a pretty hefty chassis and would probably be better in an accident than an Imp
froggy
| posted on 14/8/06 at 08:27 PM |
i wouldnt listen to common sense when i was 16 either! , i bought a singer chamios for ten quid and did three head gaskets in two months before
binning it for a rotten minivan which took no end of abuse until it ran out of mot ,this was when riveting plates over rot was ok
