macspeedy
posted on 25/6/03 at 08:39 PM |
weber carb jets
I am aware of the sites and books that advise you on which chokes and jets to fit to different levels of tune but obviously each engine is different,
i see myself ending up buying loads of different jets etc and only needing a few? anyone know where i could borrow some from? I am fitting twin
45's weber to pinto with a fr32 kent cam, ported and 3 valve seat angles cut... standard bottom end balanced and 6 kg flywheel.
Jon Ison
posted on 25/6/03 at 09:09 PM |
there is only one way to do this, rolling road..... go to some one who knows there stuff n most won't even charge for jets as they will keep the
ones they take out...
anything else is guess work and won't work, (not at its best anyhow)
