Author: Subject: Swirl Pot
bodger
posted on 21/3/07 at 06:34 PM Reply With Quote
Swirl Pot
Am I right in thinking that flow is into the pot through the lower pipe & out through the higher?
Any considerations to take into account when mounting to ensure it functions correctly? (It's in cooling system).
miegru
posted on 21/3/07 at 06:45 PM Reply With Quote
I thought that the use for a swirl pot is to seperate possible air from the water. If so, the logical connection would be to for the water/air mix to enter though the higer big opening, for the water to leave through the lower outlet and for the air to go out via the connection at the highest -point (connected to the de-air ciruit).
Makes sense?
bodger
posted on 21/3/07 at 07:25 PM Reply With Quote
Yes that makes sense. Must have been having a bit of a blond moment.
lsdweb
posted on 21/3/07 at 09:26 PM Reply With Quote
Hi Bodger
I assume it turned up in the post today then?
Wyn
bodger
posted on 21/3/07 at 10:26 PM Reply With Quote
Yep, thanks very nice.
lsdweb
posted on 22/3/07 at 07:53 AM Reply With Quote
Good! I'm glad.
bodger
posted on 22/3/07 at 12:41 PM Reply With Quote
On the pot I've got the bigger pipe (32mm) is at the bottom & the smaller pipe (25mm) is higher up. I would have thought the bigger pipe was for the inlet & the smaller the outlet? So which way around is it?.
lsdweb
posted on 22/3/07 at 01:27 PM Reply With Quote
I thought it was the other way round!
And that's what the guy made when I asked for a swirl pot for 25mm outlets on the engine and 32 mm inlet on the rad.
bodger
posted on 23/3/07 at 09:12 PM Reply With Quote
Ah I've got it now. Pot goes in the return line from engine to rad. I was thinking you plumbed it into the supply.
