kelloggs
posted on 24/3/07 at 06:51 PM |
help
can anyone living close to me with previos experence of sva tests help me to check the car over before I send it off for it's sva test, promise
to look after you food, drink etc.
graememk
posted on 24/3/07 at 06:56 PM |
muz chap lives over you way and only sva'd last year
why not put a few pics up on here for us to look at
[Edited on 24/3/07 by graememk]
ReMan
posted on 24/3/07 at 07:19 PM |
When is the SVA?
What do you mean by send it off? Is'nt this the excuse you've been waiting for to take it for a drive, legally?
I'd happily come over, any excuse and all that but it depends on your timescale and the weather
Else as mentioned, start by posting some pics up here
Col
posted on 24/3/07 at 07:46 PM |
When's SVA? My parents live up in Hambleton so might be popping up at some point.... Toying with the idea of driving up for a few hours during
the day on Monday! Weather looks promising and I think they might be around...
kelloggs
posted on 25/3/07 at 09:33 AM |
help
thanks for your replies sva not sent off yet photo's are in my photo archive
ReMan
posted on 25/3/07 at 11:44 AM |
Plenty of time then!
From what I can see, you need a bit more trim on your hanbrake!, some cover over the trach rod extendion nuts and the upper wishbone camber adjustment
nuts. If the dash is a thin sheet without a return, then the rubber on the bottom may not be enough? Possibly out center mirror may need some too.
I'm sure others may disaggree or spot something else, but it's looking pretty good.
Remember , theres a lot to be said for the fact that if it looks right, it probably is
jollygreengiant
posted on 25/3/07 at 02:12 PM |
I think you will find that you need some side mirrors as well.
Looks good. does this mean you will be driving it to stoneleigh.?
[Edited on 25/3/07 by jollygreengiant]
kelloggs
posted on 25/3/07 at 06:36 PM |
cheers for advice
Carpet for centre tunnel and gaters for handbrake and gear stick setting ready for fitting, dash made of carbon fibre and has no return and is a
little floppy in the middle. Thought the trach rod and camber nut adjustments would need covering. Was told by luego to buy areo mirrors from demon
tweeks for sides, not sure that these are good enough for sva any advice welcome.
