lid0n
| posted on 29/3/07 at 03:10 PM |
pinto ignition system
i want to change my pinto points to an electronic system can any one recommend a setup?
mookaloid
| posted on 29/3/07 at 03:44 PM |
The Aldon Ignitor is a cheap and easy way to do this.
It just replaces the points and works well for me.
If you want a customisable ignition map then Megajolt is the obvious way to go but be ready for a fair bit of fiddling - oh and it won't be
fitted and running in about 20 minutes
Mark
jacko
| posted on 29/3/07 at 03:51 PM |
Hi give H&H ignition salutions a ring on 01384-261500 there very good with pinto ignitions or try a megajolt
mookaloid
| posted on 29/3/07 at 04:00 PM |
Hi Jacko,
What does your dizzy use for points?
mark
jacko
| posted on 29/3/07 at 04:20 PM |
Hi Mark on points in the dizzy . all electric they modify the dizzy and provide a new coil when i got mine it was £100+vat
Graham
DarrenW
| posted on 29/3/07 at 04:37 PM |
Shameless plug
As soon as i road test megajolt install i will be selling my electronic ignition set up. It is the std Sierra electronic, based on a brand new dizzy
(now only done 3,500 miles). I have the wiring, coil, leads, new dizzy cap and rotor arm fitted etc. U2U me if interested and we will work out a
price.
Just depends if you want std electronic or a modified dizzy set up like what Jacko suggests.
Regards,
Darren.
jacko
| posted on 29/3/07 at 04:44 PM |
Hi Darren we are the pinto boy,s
[Edited on 29/3/07 by jacko]
DarrenW
| posted on 29/3/07 at 04:59 PM |
Mark
I can vouch for that with MJLJ - took me at least 35 mins
Seriously it is not a bad way to go but not your budget electronic option and some learning of 3D mappable systems and bits to use is required.
The system iam just removing did me proud until i got into the upgrade mode. Im basically prepping for bike carbs hence modding the ignition and
getting it all de-bugged first.
The good news about a std electronic system is that it is a saleable item should you wish to upgrade later.
Jacko - i believe you might be right  There is a good core team of dedicated Pinto followers on here. Who needs a low torque bike engine!!!!!
[Edited on 29/3/07 by DarrenW]
lid0n
| posted on 29/3/07 at 05:19 PM |
u2u sent darrenw
mookaloid
| posted on 29/3/07 at 05:58 PM |
Jacko,
You need to have a look at an Ignitor -my car was vastly improved when I binned the points and put the ignitor in - an I haven't had to look at
it since
Mark
jacko
| posted on 29/3/07 at 06:08 PM |
Mark i have a modifed dizzy fitted why do i need another ? its fully electric
Graham
mookaloid
| posted on 29/3/07 at 06:11 PM |
the ignitor just replaces the points - it goes in your existing dizzy. It has no effect on the advance curve, but it does give a better spark and
better starting, it doesn't go out of adjustment or wear out like points do.
Mark
mookaloid
| posted on 29/3/07 at 06:23 PM |
pic
TangoMan
| posted on 29/3/07 at 08:08 PM |
So Darren how's it running now. I have managed to map both fuel and ignition in a weekend so I hope you are well sorted ready for Monday.
I agree about who needs a low torque bike engine. Long live the Zetec
[Edited on 29/3/07 by TangoMan]
Summer's here!!!!
DarrenW
| posted on 29/3/07 at 10:19 PM |
Steve - Car ticks over and revs very well. Havent had chance to road test yet as ive decided to take front suspension to bit to paint up some scabby
horrible looking bits. Will have it all back together by weekend. Will probs map it on drive to Boro' on Monday!!
Im running out of time so dare bet ill be in 2D mode for the track. Cant wait to see your set up. Might give me some throttle body inspiration.
Mooky - i thought Jackos dizzy didnt have points. I seem to recall it is an electronic dizzy with modified advance curve (no vacuum). His earlier post
said 'on points', i think it should have been typed 'no points'. Might be wrong though.
mookaloid
| posted on 30/3/07 at 03:05 PM |
I've realised now
Duh - I'll get me coat.........
bob
| posted on 30/3/07 at 03:15 PM |
I was thinking on different lines here,i used the Bosch electronic dizzy and this amp.
bob
wired like thisImage deleted by owner
jacko
| posted on 30/3/07 at 04:06 PM |
HI mark [mookaloid ] sorry i must learn to spell i meant NO POINTS not on points
Graham
