piddy
posted on 16/4/07 at 10:32 PM |
Mega jolt/X flow
How easy would it be to use a mega jolt on a 1700 Xflow?
I've got a mate that is thinking of using one on his Westfield.
Would he have to fit a toothed wheel to his crank? or is there another way to get the signal?
UncleFista
posted on 17/4/07 at 02:14 AM |
Simple, I just used a longer crankshaft pulley bolt and bolted the toothed wheel to the front of the pulley.
It's not welded or dowelled, and against all my predictions has gone a few thousand miles without moving.
Picture here
Tony Bond / UncleFista
tobymack
posted on 17/4/07 at 07:08 AM |
mine is similar but after mounting the wheel I drilled through the lot and used a roll pin to stop it turning.
I've yet to run it so I am not sure yet if that VR sensor bracket is rigid enough but it is much stronger than it looks...
