Author: Subject: Speedohealer Help
mike smith1
posted on 24/4/07 at 08:01 AM Reply With Quote
Speedohealer Help
Hi another post after the rolling road session last nite!
Mainly for the guys using the Speedo Sensor out of the blade box, picking up magnets on the prop.
The rolling road was reading 50mph and the clocks were reading 20mph
So with all the calculations done this is an error of 125% this is out of the range for the standard speedo healer (-99.9% to +99.9%) The question is, with 8 Magnets do i just add more magnets or do i fork out for the speedohealer that they make that does a wider band?
I'm begining to panic now as SVA is only a week away.
Can get back to the rolling road this weekend to re check everything.
Please read my other post about emissions help as well in the BEC Section
Thanks Mike
smart51
posted on 24/4/07 at 08:03 AM Reply With Quote
If you set your speedo healer to 99.9% then at 50 MPH it would read 40 MPH, right? OK, so not good but is it enough to pass SVA if you don't fix it properly in time?
mike smith1
posted on 24/4/07 at 08:11 AM Reply With Quote
I set it to 99.9% and according to the rolling road at 30mph it was reading around 28mph etc but at higher speeds like 60mph it was reading 60mph
Its confusing me!
Mike
graememk
posted on 24/4/07 at 08:39 AM Reply With Quote
just for sva get a cheap bike speedo
mike smith1
posted on 24/4/07 at 01:21 PM Reply With Quote
Hopefully should have sorted it, ordered the special model that does -999.9% to +999.9% so that should get around the problem.
I will have a speedo healer for sale once this is installed and working!
Mike
