oadamo
| posted on 7/5/07 at 11:36 AM |
gsxr throttle bodies
hi ive striped down to take the 2nd butterflys out do you just fill the holes on the ends do you have to fill the ones joining the bodies together.
and these are going on a 2L zetec can i use the standard zetec injectors.
thanks to all that have helped me hope iam not p**ing you off with all my questions lol
adam
oadamo
| posted on 7/5/07 at 11:42 AM |
this is a better pic of what i mean
adam
Catpuss
| posted on 7/5/07 at 01:07 PM |
quote: Originally posted by CaLviNx
Hi
I understood exactly what you meant the first time, and again any holes you have since removing the secondary butterfly spindle, fill them up.
[Edited on 7/5/07 by CaLviNx]
Absoultley. These are on the wrong side of the air filter so should be bunged up.
Self tapper will (Prolly best to cut any bit off that is protruding inside the bodies).
You could even just put the old bar though if you wanted.
matt_claydon
| posted on 7/5/07 at 02:11 PM |
I'd be inclined to say it doesn't matter. The only air that could come through those holes would be from the adjacent body, which would
already have been filtered. Since the holes are before the butterflies it won't have any effect on the amount of air flowing to the
cylinders.
Edit: This assumes there is no way for air to get in through those holes that has not been filtered - I'm not that familiar with the shape of
the casting on these bodies. If 'dirty' air can get in then yes, they need to be bunged up.
[Edited on 7/5/07 by matt_claydon]
oadamo
| posted on 7/5/07 at 02:21 PM |
cylinders.
no air can get in as its sealed from one to the other side.its drilled in the casting.
thats what i thought but i wanted to make sure as its the first time iam using bike bodies
adam
violentblue
| posted on 7/5/07 at 04:08 PM |
I'd be tempted to tie them together in a vacuum manifold, if you're using a map sensor based injection system
a few pics of my other projects
martyn_16v
| posted on 7/5/07 at 04:53 PM |
They're outside the butterflies, won't see much vacuum there.
I reckon you should be OK to leave those holes open, but on the other hand if you're filling the outer ones it's not much effort to do the
rest while you're at it...
oadamo
| posted on 7/5/07 at 06:55 PM |
ture iam just being lazy lol. ill fill them all in then i shouldnt have a problem thanks all
