Author: Subject: zetec over bore
oadamo
posted on 31/5/07 at 06:47 PM Reply With Quote
zetec over bore
hi does anyone no if a zetec 2L blockcan be bored out to 97mm as ive been given some fored pistons that can take 600bhp and i want to fit them now now now lol
adam
ned
posted on 31/5/07 at 06:49 PM Reply With Quote
97mm sounds huge, what's the standard bore on a zetec? My xe is bored out +2mm from 86-88 so in now a 2.1 and that's on the limit for a 'standard' block unless you get a purpose made ally block with offset bores (upto 90mm) and have a lot of £ to spend!
Also bear in mind the gudgeon pin size may be different and require special rods making up, also the piston crown and squish/compression and valve recesses etc may be completely different, basically it will cost you more than the power the engine will produce to fit them if it's even possible (ie buy a better/faster/more powerful engine to start with)
Ned.
[Edited on 31/5/07 by ned]
beware, I've got yellow skin
oadamo
posted on 31/5/07 at 06:52 PM Reply With Quote
Ned.
84.8 standard this doesnt sound good already
ned
posted on 31/5/07 at 06:53 PM Reply With Quote
The wall thickness of the block won't even be that thick, they will never fit, that's over 1/2" oversize!!
Ned.
oadamo
posted on 31/5/07 at 06:55 PM Reply With Quote
iam gonna sellotape them to the block then at least they will look good
adam
ned
posted on 31/5/07 at 07:04 PM Reply With Quote
[exits stage left - quickly]
oadamo
posted on 31/5/07 at 08:42 PM Reply With Quote
thanks for your help ned
anyone no whats the max you can bore a 2L zetec out to iam gonna look at buying some proper size pistons lol
adam
[Edited on 31/5/07 by oadamo]
djtom
posted on 31/5/07 at 10:21 PM Reply With Quote
If it's for a zetec turbo conversion you can use the vauxhall c20let or c20xe (?) pistons with an overbore to 2.1 - the early ones are supposedly forged and conveniently drop the CR down to about 8:1, but they are not as good as using decent forged pistons and will melt at about 1 bar boost. That's what I gathered from my ZT research anyway. I decided to just use a decompression plate until I could afford some proper pistons.
97mm bore? what the hell were they out of?! Think you'd find the pistons would overlap between the bores.... :-)
Tom
