Author: Subject: Air Compressor
scottc
posted on 27/6/07 at 01:27 PM Reply With Quote
Air Compressor
Air Compressor - £69.99
looks like a rebadged Wolf / Craft item to me.
TOOLTEC
· 50 litre tank
· 2hp motor
· 8 bar maximum pressure
· Direct drive
· Oil-filled sump tyre
· Automatic thermal cut-out
· Twin gauges
· Fully controllable output pressure
· Tank drain capacity
· Carry handle
· Wheel for easy handling
· Quick connector to efficiently connect air tools
· Air tools not included
http://www.netto.co.uk/internet/nettog/catalogue/catalogue.nsf/webActiveCataloguePages/1-6?OpenDocument&catid=1
[Edited on 27/6/07 by scottc]
speed8
posted on 27/6/07 at 02:49 PM Reply With Quote
Hmmm, this could be just what I need to get the motivation to finish off a load of rivetting I still have to do. Keep putting it off as my body can only take so much abuse.
stevebubs
posted on 27/6/07 at 04:40 PM Reply With Quote
Air rivetters rule...*so* much easier you'll wonder what you did without it...
rayward
posted on 27/6/07 at 04:44 PM Reply With Quote
looks the same as the aldi one from while ago, pretty good, only prob is the hose they give you is too small bore,
get a decent bore hose, and they;re spot on
Ray
speed8
posted on 28/6/07 at 03:00 PM Reply With Quote
Ah well... went and got one this afternoon and a few air tools. The tools themselves look identical to the Clarke tools, just a different name on them and about 1/3 price. It seems to run fine but I'll test it out when I get a chance.
