greglogan
posted on 2/10/07 at 08:07 PM |
Nuts & Bolts
Hi Guys
do I need high tensile bolts for the suspension components like the wishbones to chassis and dampers to chassis?
Greg.
Women are meant to be loved, not understood.
stevec
posted on 2/10/07 at 08:08 PM |
8.8 Minimum is recomended.
greglogan
posted on 2/10/07 at 08:12 PM |
Thanks. Any idea on what the normal sizes required are?
Greg.
ned
posted on 2/10/07 at 08:47 PM |
will depend on the chassis ie what size the bracket holes are drilled to which should in turn be to suit the size on your shocks and wishbone
bushes/crush tubes...
[Edited on 2/10/07 by ned]
beware, I've got yellow skin
Macbeast
posted on 2/10/07 at 09:33 PM |
Mine are 12mm.
RazMan
posted on 2/10/07 at 10:27 PM |
Probably either 12mm or 1/2"
Raz
designer
posted on 3/10/07 at 08:24 AM |
The minimum size to use in critical areas is 8mm.
VinceGledhill
posted on 3/10/07 at 08:37 AM |
Mine are 12mm
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
