Author: Subject: Fuel Pump Seal
mistergrumpy
posted on 7/10/07 at 05:47 PM Reply With Quote
Fuel Pump Seal
I've an SV650,(no superbike granted but its enough for me) and the rubber seal has gone on the fuel pump. Suzuki only sell them with replacement pumps at 50 summat quid. Has anyone any idea where I can just get a seal? Its like a long oval shape with two cross members. Alternatively woulg instant gasket be okay on a fuel pump? Its only a small pump, maye an inch and a half by half inch and bolts to the outside of the fuel tank with the filter sticking inside, the seal goes on the outside of the tank sandwiched by the pump.
mark chandler
posted on 7/10/07 at 05:58 PM Reply With Quote
You need special fuel resistant instant gasket, normal silicon stuff will go all floppy and rot in fuel after a few days.
Try having a look at the seals on winscreen wiper tanks weher the pump plugs into the plastic bottles, you get different sizes so may be able to match something
mistergrumpy
posted on 7/10/07 at 06:05 PM Reply With Quote
Don't think no standard car ones will fit its sorta CI_D that shaped but with another line connecting the I and D if that makes sense
