Author: Subject: flasher relay identification
jabbahutt
posted on 2/11/07 at 02:06 PM Reply With Quote
Yep it's electrical idot again I'm afraid.
I removed all the original relays etc from the donor when it was stripped. i thought then I'd be able to use the original flasher unit.
Going from the Vicky Green loom diagram there are three wires gong to the flasher unit so I assumed (probably wrongly) to look for a unit with three connectors. would the flasher unit of been located with the relays on the donor?
All the units, relays etc have 4. How do identify a flasher unit from all the other relays as they all look the same just slightly different sizes and colours, and if my original had 4 pins how do you know which one to connect which wire to as I must admit I haven't a clue.
Any help much appreciated.
Nigel
mookaloid
posted on 2/11/07 at 02:45 PM Reply With Quote
The flasher unit in the sierra is under the dash somewhere near the steering column - I missed it from my donor too!
It is not with the other relays under the bonnet.
Mark
DarrenW
posted on 2/11/07 at 03:03 PM Reply With Quote
I fitted a new one from halfords. Easy to recognise as i wrote "flasher" on it.
mookaloid
posted on 2/11/07 at 03:08 PM Reply With Quote
Your not just a pretty face Darren
However I feel you may just be missing the point a little - he doesn't have the advantage of taking out of a new package which also has the word 'Flasher' printed on it
Mark
DarrenW
posted on 2/11/07 at 03:13 PM Reply With Quote
I know - i couldnt resist. Must be that Friday feeling
Does the Hynes manual offer some ID?
DarrenW
posted on 2/11/07 at 03:17 PM Reply With Quote
Im on a guilt trip now
Does this help?
http://www.colinusher.info/Robin%20Hood/wireap3.html
jabbahutt
posted on 2/11/07 at 03:29 PM Reply With Quote
Thanks for your help, yep I missed the original on the donor, never mind.
so would I be correct to assume from the above link then that a flasher unit is also a relay as I've read threads here advising to use a relay in conjunction with the flasher unit.
Is it a relay as well or do I need a seperate relay. The vicky Green just so the three swires with to flasher unit on which I assumed meant it didn't need one.
Thanks for the help anyway it's much appreciated and it would be great if the relays etc in Halfords had it's use on the side in big letters for fools like me top idea
martyn_16v
posted on 2/11/07 at 03:49 PM Reply With Quote
look for numbers stamped on the base of the relay, sierra type flasher relays have 49, 49a and 31 stamped on them, whereas a 'normal' relay will have 30,85,86,87 (and maybe either 87a or 87b)
RazMan
posted on 2/11/07 at 04:28 PM Reply With Quote
I was just going to say that
Raz
posted on 5/11/07 at 03:13 PM Reply With Quote
me too!
take a look at VWP. relayu page. hey show relay conections using this number system so you can figure out what is what.
jabbahutt
posted on 5/11/07 at 03:37 PM Reply With Quote
what's vwp? have you got a web address
jabbahutt
posted on 5/11/07 at 03:38 PM Reply With Quote
doh vehicle wiring products!! sorry got my stupid Monday head on, wait come to think of it I waer the same one all week
Thanks for the tip
