Author: Subject: Combustion chamber/piston cleaning
Benzine
posted on 7/3/08 at 11:48 AM Reply With Quote
I'm taking an engine apart and the combustion chambers/valves and pistons are a bit sooted up. I've got most of the carbon/soot/whatever off with petrol and a toothbrush. There's still some stubborn stuff there still, anything I can use to shift it?
locoboy
posted on 7/3/08 at 11:52 AM Reply With Quote
autosol and a polishing buff in a dremell type tool?
Locoboy
Benzine
posted on 7/3/08 at 11:55 AM Reply With Quote
Just googled imaged it, sounds good
Fred W B
posted on 7/3/08 at 01:15 PM Reply With Quote
Fine wet and dry paper with paraffine and a bit of elbow grease also works well.
Fred W B
r1_pete
posted on 7/3/08 at 02:49 PM Reply With Quote
For a lazier method, spray the bits with WD40, repeat a few times, it does soften the carbon deposits, making removal easier.
Worked well for me on some bike pistons and valves.
RazMan
posted on 7/3/08 at 03:16 PM Reply With Quote
Another vote for Solvol Autosol - I've done loads of bike engines like that. The shinier the finish the less 'sticky' it will be for the carbon.
Raz
Benzine
posted on 7/3/08 at 03:18 PM Reply With Quote
Just back from town, got some autosol, just the ticket! thanks
posted on 7/3/08 at 06:57 PM Reply With Quote
Gasket stripper will lift carbon quickly but don't leave it on pistons for too long. Less effort than Autosol as well.
ReMan
posted on 7/3/08 at 08:11 PM Reply With Quote
rotary wire brush in the drill type thing.
Valves in the drill and emery cloth
Wood chisel to scrap the pistons.
Benzine
posted on 7/3/08 at 09:02 PM Reply With Quote
Is gasket stripper the same as paint stripper? I looked on ebay for some and some of them are shown as "paint and gasket stripper"
