matt.c
posted on 20/4/08 at 10:15 PM |
DVDR drive
Right i know sod all about pc's so here we go.
I have a DELL pc which has a CDR drive in it and i need a DVDr drive. Can i buy a dvdr drive and plug it in some where or can i replace the cdr drive
for a cdr/dvdr drive? How hard is it to change the drive?
Plus i need it as cheap as possible.
Sorry for being a dumb arse!
cheers
matt
graememk
| posted on 20/4/08 at 10:20 PM |
how old is the pc as the newer dells are sata where as the older ones are ide....
if its only got a cd in it will be IDE, i'll u2u you with a recomendation.
dead easy to do as well.
[Edited on 20/4/08 by graememk]
blakep82
| posted on 20/4/08 at 10:24 PM |
theres always the usb option. bought a dvd rw last year, got a feature called light scribe (it can write a lable on special cds and dvds) and runs
fine on my laptop which must be about 6 years old now
________________________
| posted on 21/4/08 at 08:39 AM |
If it's got a CDR drive it will almost certainly be an IDE/PATA interface. You can just buy a DVDR/RW drive (cheap as chips these days) and
replace the CDR drive with it, ensuring you use the same jumper option (Master/Slave/CS).
If you want to keep the CDR drive then you can add the DVDR/RW drive to the system provided you have a spare power and IDE connector.
graememk
| posted on 21/4/08 at 10:12 AM |
will drop over in the week and get it fitted for you mat
